Networks Cloud hosting
Discussion in 'Tech Support' started by mr.a2008, 2 Feb 2013.
  1. mr.a2008
    mr.a2008 What's a Dremel?
    3 Aug 2009
    HI all,
    I dont know if that this is the right place to put it but I am currently looking to buy some cloud space for myself and a few friends. We are only looking for a minimum of 20-30GB. Doesnt have to have a lot of RAM or CPU processing power. Just low costing for the year with ftp. Can be Linux distro on there. Very familiar with it so it is all good.
    Any advice and places where it is cheap to buy for the year?
    Mr.a
  2. Votick
    Votick My CPU's hot but my core runs cold.
    21 May 2009
    Whats it going to be used to host?
  3. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    you should have a look into Amazon EC2 - it's priced as you use it and you can use lots of different spec'd instances.
  4. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    skydrive
  5. CraigWatson
    CraigWatson Level Chuck Norris
    9 Apr 2009
    I could give you some space on my server (hosted with Hetzner with 100Mb connectivity) if you like - PM for details, I'm pretty sure we can work something out price-wise :)
  6. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    TSO Host also do cloud hosting at reasonable rates.
