Watercooling Help with setup
Discussion in 'Hardware' started by Strudul, 18 Apr 2011.
  1. Strudul
    Strudul ~
    31 May 2010
    I have always wanted to watercool. But always been too scared. After reading every guide I could find several times, I think I am gonna give it a go. Give myself something to do over the summer holidays.
    My rig is in the sig, but will be upgrading the gfx and possibly adding that to the loop.
    This is what I am thinking, but I have no idea how well it will work.
    I am not sure about the positioning of the pump and res. And I dont know yet how I am gonna fill/bleed it.
    I don't think I can fit the rads inside, and since I dont want to buy another case, I think I am gonna mount them externally. I dont have a clue about specific parts yet, I am still trying to work out exactly what I need.
    Any help is appreciated
    Thanks
  2. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    You can only go in one direction per rad. So it'll be 120.1, then 120.2, then the CPU, but that should do you fine for most things. Just remember to keep good airflow through the case. Your CPU might be nice and cold at the end of the day, but GPU's don't like static air in a case.
    Might even be able to push your overclock a bit further with a water-cooling setup.
  3. WiryRocketeer
    WiryRocketeer Minimodder
    30 Jul 2010
  4. Strudul
    Strudul ~
    31 May 2010
    Oh yeah, not thinking...
    So I want a tube going from the pump to the 120.1 then the 120.2 then a really long tube going to CPU?
    Would a 120.1 + 120.2 be enough for cooling an X4 955 and a high end gpu (480/580)
    Thanks;)
  5. Strudul
    Strudul ~
    31 May 2010
    I can't use that kit because it is Intel only right?
    But I did take a look at the Koolance Exos and a few other kits. They would make things a bit simpler, but I don't know how the temps compare to a custom watercooling setup. I also wouldn't know which to get.
  6. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    I wouldn't bother with that 120.1 rad.
    A decent 120.2 should provide plenty of cooling for just a CPU.
  7. Strudul
    Strudul ~
    31 May 2010
    But if i want to include a gpu at a later stage?
  8. Apocalypso
    Apocalypso Fully armed and operational.
    15 Sep 2007
    You could hang a 120.3 off the back using a Swiftech Radbox or something similar, that way you can cut out the extra tubing and fittings.
    That's not mine btw, I just copied it from the evga forums.
  9. Strudul
    Strudul ~
    31 May 2010
    Problem with that:
    -extra cost to buy mounting rack
    -harder to get to wires in back of PC
    -back of PC is behind TV/monitor , and that area is quite hot
    Tubing isn't very expensive, but I was thinking of compression fittings, so might save quite a bit doing that. Hmmm...
  10. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Remove the front HDD holders and you'd be able to get a 240mm rad there, wont you? Read through my thread (link in sig) :)
  11. Strudul
    Strudul ~
    31 May 2010
    I have read your thread many many times.
    I could probably get a rad in there, but...
    -I need somewhere for HDDs
    -I have a lot of cables running through that area. My cable managment is everywhere. It looks neat from the window, but round the back and in the drive area there are just loads and loads of cables.
  12. Strudul
    Strudul ~
    31 May 2010
  13. Apocalypso
    15 Sep 2007
    Bear in mind you'll exhaust warm air from the components through the rad unless you set the fans to intake in the roof.
  14. Strudul
    Strudul ~
    31 May 2010
    Can I intake through the roof and rear, then exhaust from the side and front ?
    Anyway, would this work better then?
  15. Bloody_Pete
    11 Aug 2008
    Well, what I was thinking was:
    Move the HDD's to your 2 free 5.25" bays.
    Remove HDD holders.
    Install a slim radiator in the front.
    Now, your not cooling massively hot hardware, so the most heat you'll get off it will only be a couple of degrees hotter than ambient. With the roof set to exhaush and the rear and side set as intakes as well, you'll easily have enough cooling for your motherboard.
  16. Strudul
    Strudul ~
    31 May 2010
    But, I need at least 4 bays (1x optical, 1x fan ctrlr, 2x HDD), and I would have to do even more cable re-arrangement
  17. Bloody_Pete
    11 Aug 2008
    Ah, I didn't know you had a fan controller...
    Could drop the optical, I'm going to in my next rebuild as I use ut so rarely these days...
  18. Strudul
    Strudul ~
    31 May 2010
    The fan controller (Sentry 2) is in my rig ;P
    I dont think I could drop the optical. Got a few too many games that still need it. I tried transfering them to HDD but I could not get around the security stuff.
  19. Bloody_Pete
    11 Aug 2008
    USB optical drive... :p Or you could get a case better suited to water cooling...
  20. Strudul
    Strudul ~
    31 May 2010
    How much would another case help? And how much is a good case designed for watercooling? I am guessing about £150. And then all the watercooling stuff is gonna be ~£250 I think. Then I need a gfx card which is a min of £200 really. So £600. Which I can afford, but being only 17 (since yesterday ^^), having no job or source of income, and also thinking about driving lessons I would like to keep The spending to a minimum :(
    well sorta ;)
