Hello All, I have very recently installed Sage CRM 7.2 as we are looking to migrate/upgrade to the system from a much older version of sage, and I am stuck at the first hurdle. Exchange Intergration. I believe I have taken the steps required in the setup guide, but i just cannot figure this out. When I try to add a new connection the onscreen error reads "The sync engine is checking to see if the exchange web service is available. Please wait ..." Then the red cross shows. When I browse to the URL i have entered in the web service URL field i am asked for a username and password, i enter our domain admin username and password and I see the xml. I am using these credentials to setup the exchange intergration at the moment. My manager discovered (by a simple spelling error) that entering exhange rather than exchange in to the web service URL seems to get you past this check but then fails at the next one anyway. I just dont get it at all!! The environment consists of a windows 2012 x64 server running on vmware 5.0. I have the 32bit and 64bit odbc drivers installed as this will be pointing to an oracle database. This is installed internally so no firewalls should be in the way, and I have disabled windows firewalls. No anti virus is installed on the system. I appreciate any help with this. t2i3m
What authentication methods are you using on the EWS virtual directory? Might need basic auth enabled for it to work
we do have a cert installed and outlook anywhere is working. I am going to try a full reinstall of the server and CRM over the next couple of days. I can only assume I have missed some configuration steps somewhere along the line.
