Watercooling Which Case and kit.
Discussion in 'Hardware' started by crazyg1zm0, 31 Mar 2012.
  1. crazyg1zm0
    crazyg1zm0 Minimodder
    20 Feb 2007
    Hi there guys.
    I have got a decent ammount of cash for my birthday and am looking to finally get a WC loop.
    The main thing i need is a case with ability to take a 240mm rad without me doing anything to it, And i would prefer if the rad was internal in teh case, As i have never really been keen on external ones.
    The case i Have seen is the NZXT phantom from what I have seen its got the ability to take the 240mm rad internally without any modifications. Are there any other large cases out there that fit the bill? I have 4 HDDS to fit in 3 of which are 3.5 and the other is my SSD.
    The kit running inside that will be cooled is
    i7 2600k
    6870HD
    I am only cooling them originally wasnt going to do the GPU but i noticed that it puts out alot of heat so I think cooling it might be wise.
    For the CPU block i was thinking of using the EK-Supreme LTX
    For the GPU block i was thinking of using the EK-FC6870
    For pumps and rads etc I am have no idea of what i should look at, im guessing as its decent loop a good pump will be needed.
    What advice can you give me on parts and such? If anyone has any parts for sale that will fit me let me know as well.
    Pete
  2. ninjaplease
    ninjaplease I don't know what I'm doing
    11 Jan 2012
    The best advice I can give you is to research the hell out of the topic, checking for reviews of each part you find along the way, same as with any other part choices.
    I don't have any personal experience of watercooling, but the impression I get is that all systems are pretty unique depending on design choices, budgets and needs.
  3. crazyg1zm0
    20 Feb 2007
    Well i have found out that the Case is able to fit a 240mm rad in fine without modding.
    The main questions is what fans are best and such.
  4. ninjaplease
    11 Jan 2012
    I've recently acquired some Sharkoon Silent Eagle 2000s and I can recommend both the 80mm and 120mm versions, if they'll fit. Just have a flick through the selection on ebuyer and read the specs and reviews.
  5. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Have you had a read of my thread? (link in sig) It'll go through alot of questions :)
  6. ninjaplease
    11 Jan 2012
    If I may ask, how???!1!one
  7. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    Uni network.
  8. ninjaplease
    11 Jan 2012
    figures
  9. crazyg1zm0
    20 Feb 2007
  10. mars-bar-man
    17 Apr 2009
    • Anti-kink coils, not needed unless you plan on some tight bends
    • You don't need the extra screws
    • That 240mm rad won't be enough to cool it efficiently. Get either a ticker one, or a 120mm rad as well
    • Coolant? I'd say get a kill coil and go to Halfords and buy some Distilled water.
  11. Bloody_Pete
    11 Aug 2008
    Amusingly not, it was at home in the middle of Bristol. The place where I live is simular to halls and the network management software had a helpful bug one year :p
  12. mars-bar-man
    17 Apr 2009
    Ahhh ok, I knew it was something linked to the uni.
  13. crazyg1zm0
    20 Feb 2007
    The coils are for aesthetics as I want something to be visible in the case but i don't want to use UV coolant and such.
    I cant fit a thicker 240mm rad in the case im looking at without modding or having it as an external rad which i dont want. As im looking into the NZXT Phantom case. Can anyone suggest a diff case that wont need modding that will fit a thick rad in for the same money?
    As for coolant. I will just go halfords in that case. And whats a kill coil?
  14. mars-bar-man
    17 Apr 2009
    Kill coil is a little coil of 99.9999999999999999% (roughly) silver that kills bacteria and stops corrosion essentially. It's what I'm using atm and have never had any issue, bloody cheap as well!
    You could get a 120mm radiator to pop on the rear exhaust fan if you like the Phantom that much?
  15. crazyg1zm0
    20 Feb 2007
    Yea your right i think i might just pop a 120 on the back or summit for that bit more chilling.
    Where do you get kill child from as i can't see them on aqua tuning.
    Cheers for the info boys, now to work out a loop order and see if i can get any parts from the market place
  16. crazyg1zm0
    20 Feb 2007
    On the case I'm not set on it
    If you guys can point me in the direction of a case that will do what i need would be useful
  17. Bloody_Pete
    11 Aug 2008
  18. mars-bar-man
    17 Apr 2009
  19. Bloody_Pete
    11 Aug 2008
    I prefer Specialtech TBH
    If only the site wasn't so damned slow!!!
  20. crazyg1zm0
    20 Feb 2007
    will look at the special tech site. As for case:
    I think i might be getting one form the market place with a res, 240mm and a 120mm rad in it already which will be perfect :)
    And already got a Liang DDC pump with plexi top for £55 :)
    Will have to build a log when i build it to show you all :)
