Case Mod - In Progress Bitfenix Prodigy MINI - HTPC Build
Discussion in 'Project Logs' started by HCP, 7 Dec 2013.
  1. HCP
    HCP Minimodder
    19 May 2012
    Well, not again huh ? :)
    Need a HTPC for my living room.
    Never found a case i wanted, so i took a white Prodigy i had ad remembered its pretty easy to mod it.
    == HARDWARE ==
    Zotac G41 ITX motherboard
    Intel E6600 cpu
    8GB ram
    PicoPSU
    Will try on the onboard graphics at first, if i need more power i have a 6570 low profile card to use with a riser.
    So i tested it out with some 4mm ABS plastic and it was good, will wrap it in vinyl later. And front panel goes outside of this to give it a better look anyways :)
    So here it goes, build thread No#... too many
  2. HCP
    HCP Minimodder
    19 May 2012
    Its getting closer :)
    Front panel need some more love, but in overall i´m satisfied.
    White enermax fans in the top.
    Next up, motherboard base.
  3. saxovtsmike
    saxovtsmike Minimodder
    12 Aug 2008
    cute
    Frontpanel looks really good
  4. HCP
    HCP Minimodder
    19 May 2012
    Something like this will be the end result, + a Bitfenix logo somewhere.
    Didnt have enough acrylic at home for side panels, so im testing with some white ABS.
    Made the plate for the motherboard today, and tested to install the parts, works well!
    Put together with double sided tape right now, so a bit hanging here and there :p
  5. TaRkA DaHl
    TaRkA DaHl Modder
    15 Mar 2011
    Very cool :)
  6. jamsand
    jamsand Minimodder
    21 May 2011
    wait what....Yeh cool mod on!
  7. stuartwood89
    20 Aug 2008
    Oh wow, I love squashed cases. I'll be watching this one.
  8. HCP
    HCP Minimodder
    19 May 2012
    Made some more progress in this mod.
    Side panels, i use the side panel with buttons and audio jacks from the original panel.
    Fresh from wet sanding, thats why they are dirty :p
    And here is the side panel for the black prodigy (yeah, i´m making one white, one black and one Black Phenom cut the same way)
    Some bubble-popping to do before its done.
    I was trying with adding a Be Quiet logo on the acrylic, then wrap flat black on top of it to get embossed logo, worked pretty well.
  9. BeauchN
    BeauchN Multimodder
    5 Apr 2011
    That looks great, can't wait to see the finished article
  10. HCP
    HCP Minimodder
    19 May 2012
    Had a fire at my kitchen that delayed my modding work :)
    But its close now, i think i will post both the black and white mini´s in this thread further on as they are different in some details.
  11. HCP
    HCP Minimodder
    19 May 2012
    Been working on the black one, getting closer on that one so i show progress from both the white and black in the future :)
    A mockup of all the parts.
  12. HCP
    HCP Minimodder
    19 May 2012
    Some internal pics after some work this weekend.
    Need to fix the cables, but im satisfied due to the lack of space :)
    Used a Cooler Master Seidon 120v for cooling in this one.
    Side view, not alot of space but enough for motherboard, a 2TB drive and a SSD, a 120mm radiator and all cables.
    Using a Be Quiet SFX PSU
    My custom side panel turned out good
    PSU mounted above the motherboard
    If i do another one of theese, i´ll cut a hole in the floor for PSU and put one more fan in the roof, this may be to hot. We´ll see after some testing.
    Inside gut of the Prodigy Mini, testing the hardware and installing windows right now.
    Cable management its not much room for, but some hide away i think i need to fix :)
    Red cable going to be changed also.
  13. thenotincluded
    thenotincluded What's a Dremel?
    17 Jul 2012
    Looking good, I want to do something like this :D
  14. DarkSable
    DarkSable What's a Dremel?
    24 Nov 2012
    Man, I want one of these!
    I loved my prodigy, and this is just incredible!
