Watercooling Cloudy Res :(
Discussion in 'Hardware' started by LukeDaly, 15 Feb 2012.
  1. LukeDaly
    LukeDaly Pokemon Master
    9 Jun 2011
    Hello, just wondering what could have caused my new water cooling res to get cloudy, its brand new not even a month old, every single part is brand new, I also rinsed all my stuff with white vinegar and distilled water before filling it :/ also it seems my haf-x is simply a pita to water cool in.. anybody got any idea where I could move this bloody cylinder res too as it simply looks dung here :/
    any ideas for improvements on the looks of the case are very welcome, thanks Luke
  2. asura
    asura jack of all trades
    22 Apr 2009
    My inital thought was oop, more plasterciser leaching, but opening your post and looking at the pictures... Looks like condensation; pop some more liquid in and it'll be gone.
  3. feathers
    feathers Minimodder
    11 Apr 2009
    LOL! I wondered what he was on about. Imagined cloudy liquid with fungal growth, instead what we see is a bit of condensation!
  4. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    That's always going to happen so long as your loop goes through temperature changes. Just keep it filled if you are really concerned about it.
    If anything; I'd be more concerned about your 580s cooking in that scenario. Even with a gap between my two 550Tis and a 180MM AP fan throwing air at the fans; I still see a five degree difference between the two under load.
  5. feathers
    feathers Minimodder
    11 Apr 2009
    Is that a fan/shroud feeding air into the 2 x 580's? There is something covering the front of the 580's.
  6. .//TuNdRa
    12 Feb 2011
    That looks like a support bracket to stop the cards from warping under their own weight, with holes in to feed power cables through. I doubt it aids airflow, unless there's a hidden fan in there somewhere.
  7. feathers
    feathers Minimodder
    11 Apr 2009
    I see.
    2 x 580. Nice.
  8. LukeDaly
    9 Jun 2011
    Theres a 120mm fan in the gpu support bracket, and its not condensation, ill add newer photos asap, doing thia from iphone atm...
  9. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    without saying condensation again, not sure how much I can contribute to this thread without repeating what people have said, What I will ask is that a P67 Maximus IV extreme?
  10. .//TuNdRa
    12 Feb 2011
    Quick way to check; Power off your loop, (Assuming there isn't enough coolant in the intake pipe to full this res); Remove top of res, rub cloudy bit. Is it wet? Condensation. No? I think your Res may be being eaten. If so; New coolant. Stat.
    It does just look like very fine condensation. I get it a buttload in my Balancer because the nickel top is always freezing cold. (well, almost always) so it condenses up there whenever I forget to open my window & up my fans.
  11. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    I got that in my old setup. It was from the craptastic colored fluid. It left a film as the fluid level dropped over time. If you can take the res apart, its easy enough to remove with a light scrub with soapy water. Then refill the loop with nice clean clear distilled water after a good flush. Likely that film is building in all the tubing and blocks too... it was on mine.
  12. LukeDaly
    9 Jun 2011
    its the Maximus Iv Extreme-z :)
    damn annoying -.- ill have to have a check, have to take the whole rig apart to check tho -.- so will have to wait until the weekend, i never thought that problem would occur with mayhems dye, silver kill coil and pt nuke :(
  13. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Just lean the case slightly, if it washes off it's just condensation. Mine did this loads at first, but it's clear now...
  14. thetrashcanman
    18 Nov 2010
    Pete, go check out the Marketplace, there's something possibly going up for sale you may be interested in *cough* ;)
  15. Bloody_Pete
    11 Aug 2008
    *Puts down minecraft for 5 minutes and wanders over...*
  16. thetrashcanman
    18 Nov 2010
    Worth it?
  17. LukeDaly
    9 Jun 2011
    didnt move :/ but tbh im hoping its film as mentioned before :/ i dont my new res stained already god dammit -.-
  18. feathers
    feathers Minimodder
    11 Apr 2009
    Ahhh! So there is a fan in there. It kind of looked like it could house a 120 fan.
    It still looks like condensation from what I can see but maybe I'm wrong. If you tilt and swish the res and it gets rid then it's condensation... if it stays then you are right... it's not condensation.
    Are u using straight distilled water?
    I would use Thermochill EC6.
  19. LukeDaly
    9 Jun 2011
    Yeh im using distilled, silver kill coil, and pt nuke :/
  20. thetrashcanman
    18 Nov 2010
    I doubt its the Mayhem's dye its pretty good stuff, is that an Ek Copper block?
