Case Mod - In Progress Project Haswell
Discussion in 'Project Logs' started by Brian, 22 Mar 2013.
  1. Brian
    Brian What's a Dremel?
    2 Oct 2012
    Hey guys I am starting a new project except this one is actually going to be for my personal daily use computer.
    This will be a completely customized Cosmos II that will not resemble the original Cosmos except for some slight resemblance)
    Sponsors for this build are:
    Cooler Master
    MNPCTECH
    List of parts to be used:
    Cosmos II
    3 EVGA GTX Titans(hydrocopper) in triple SLI
    Motherboard: to be determined but it will be a Haswell chipset motherboard
    CPU: Haswell (to be determined upon release)
    Swiftech GPU waterblocks
    CPU waterblock: Swiftech
    PUMPS: 2 Swiftech pumps
    Reservoirs: to be determined
    Rads: 1 480, 1 360 & 1 240 (to be determined)
    Fans: Cooler Master Excaliburs
    PSU: to be determined
    Sleeving: MDPC
    Coolant: Alphacool pure water and Mayhems to be determined
    SSD's: 6 SSD's in RAID 0 possibly Plextors or Samsung Pro series[/I][/B][/SIZE]
    Mnpctech Pre-Ordering page for Cooler Master Cosmos II Clear Window Panel
    Basically I am completely stripping down this case, removing the midplate and fabricating my own based on the motherboard when it is released. Also the entire front I/O shield will be deleted and a 480 rad will be mounted there after I delete the entire 5.25" bays and the HDD bays. I will be using a custom overkill grill from MNPCTECH on the intake. I will be mounting a 480 rad up top and also using an MNPCTECH overkill grill there after I fabricate the flush mounting solution around the current top panel.
    Also I am almost sure that I will be housing both pumps down below in the PSU section of the case. The top handles will be deleted from the case as well as the roll bar type feet currently on the case. The side panel will be a solid custom acrylic side panel that will be mounted directly to the factory oem door hinge so you will be able to see every inch of the inside of this case mod.[/SIZE]
    Here are some basic pictures of what I have deleted so far out of the case. (Definitely getting rid of the Octopus front I/O shield, just has way too many wires for my taste and I will be installing a custom fan controller)
    Well as some of you know I got in 2 of the GTX Titans today. I have to say these are the nicest looking and feeling air cooled cards I have ever owned. Swiftech blocks will be coming hopefully within less than a week as well as backplates. Here are some pictures
    Have around 7 weeks to wait till 480 overkill grills so I can fab out the entire front bezel of the cosmos II as well as the top extension.
    G0UDG likes this.
  2. YEHBABY
    YEHBABY RIP Tel
    22 May 2010
    Those Titan's are pure GPU Porn :)
    I look forward to seeing how your build progresses :thumb:
  3. WhatTheTech
    WhatTheTech Macmodder Addict
    18 Dec 2012
    Honestly, I don't even care what the case ends up looking like...I just want pics of your Titans and SSD RAID set-up :D
    Seriously, subbed.
  4. WhatTheTech
    18 Dec 2012
    (I guess you can make the case look nice too ;) )
  5. Phame
    Phame COOOOFFFFEEEEE
    17 Sep 2012
    3 OF THEM? :O
    Can't wait for this dude! MOAR NOW(ISH)
    :D
  6. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Hey Brian, check yr email, I got that quote to you finally :thumb:
  7. Reiep
    Reiep What's a Dremel?
    21 Jun 2010
    Wow, pretty badass setup. For gaming, folding, both ?
  8. dombak1608
    dombak1608 What's a Dremel?
    3 Apr 2012
    Very nice beast. :jawdrop:
  9. Dragulax99
    Dragulax99 What's a Dremel?
    9 Apr 2012
    eye candy ...
  10. wejjy
    wejjy Minimodder
    9 Aug 2010
    Subb'd for two reasons,
    1. Tri Titans!! AwEsOmE!!
    2. Someone completely stripping a case of this size/value, its got to be good!!
  11. mnpctech
    21 Apr 2003
