Displays GTX1060 will only see one display at a time
Discussion in 'Tech Support' started by Cthippo, 18 Feb 2017.
  1. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    I've got a MSI GTX1060 3GB GPU in my system and I'm trying to set up a second monitor. The primary monitor is connected to the card over DVI, but when I try to attach the secondary monitor on a HDMI connection the main screen loses signal and only the secondary screen is visible. When i check the settings using the secondary screen it only shows that screen. How do i get it to detect both screens at once? :confused:
  2. Dopeyman
    Dopeyman Minimodder
    10 Jan 2011
    Have you tried plugging them both in with pc turned off?
  3. Cthippo
    7 Aug 2005
    Indeed I have. Seems like any time the HDMI is plugged in the DVI becomes inoperable. :(
  4. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    ISTR this used to be a thing with GPUs, possibly because HDMI is a cut-down DVI connection.
    You might have to go DP/HDMI or 2xDP to fix.
  5. Cthippo
    7 Aug 2005
    OK, DP to HDMI cables are less than $10. Maybe give that a shot.
    I guess if all else fails I have a GT320 card here which is entirely adequate for running a secondary screen.
  6. killingit
    killingit What's a Dremel?
    23 Feb 2017
    Hmm, this seems to be a weird issue. This can be driver related. Have you tried using Display Driver Uninstaller and reinstalling the graphics driver?
