Other A "sketchup" software
Discussion in 'Software' started by mecblade, 1 Sep 2010.
  1. mecblade
    mecblade 14 year old Technophile
    12 May 2010
    ive been quite interested in designing a case during te recent months but ive yet to find a sketchup program which is useful. Ive tried Google's but it doesnt quite cut the cake for me. Can anyone with experience in sketching up stuff like this (Im looking at you scratch build modders! :) ) recommend me a nice program? thanks in advance
  2. bigkingfun
    bigkingfun Tinkering addict
    27 Jul 2008
    I know I have been saying it for a couple of years now, but I really am designing something.
    I use AutoCAD 2008 to make the parts, because I find it easy to rotate and move parts as you want:
    When I need to make a render, simulate airflow or make detailed fabrication-drawings I use SolidWorks 2009:
    It took me 2 weeks to learn the things I use in AutoCAD, and a little longer to use SolidWorks.
  3. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    pro engineer cant get much better than that (not sure how you would get hold of it though)
  4. Booga
    Booga Cuppa tea anyone?
    28 Sep 2009
    All of the above suggestions are good not sure where you would get a copy of any of them for a reasonable price.
    I use UG NX at work but would recommend Soliworks as it is simple to use and probably easier to pick up than NX.
    Solidworks effort.
    Solidworks drawing
  5. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    I wouldn't mind trying a program like this, but I need one that is very user-friendly and extremely UNtechnical, as I haven't the faintest about CAD.
  6. Booga
    28 Sep 2009
    Solidworks is fairly simple to get the basics of.
    It is sketch based so like SketchUp you just draw a shape and extrude, rotate or follow a path.
    You can also model from primitives as well, which means throwing in a shape and sculpting it essentially.
    The assembly mate conditions are also relatively easy to pick up too if you are brave enough to try assemblies.
    I am sure with a few tutorials any computer savy person could pick up the basics in no time.
    :thumb:
  7. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    Trouble with Solidworks is the cost - unless you're a student...
  8. Booga
    28 Sep 2009
    Yep that is why I said I didn't know where you would get such a package at a reasonable price.
    It can be found very cheap but I would not condone that.
    I don't know whether FreeCAD is worth keeping an eye on and trying.
    I tried it briefly and it shows some promise.
