Cooling
Discussion in 'bit-tech Folding Team' started by johnim40, 15 Jul 2013.
  1. johnim40
    johnim40 Minimodder
    23 Apr 2009
    hi guys
    what do people use to cool there rigs mainly gpu other than watercooling or standard case fans
    cheers for any help
  2. TaRkA DaHl
    TaRkA DaHl Modder
    15 Mar 2011
    Open cases. In a separate room with the windows slightly open. If a multi GPU rig consider using PCI risers and a modified case setup to keep cards further apart. Folding doesn't need lots of PCI-E lanes, x1 will work fine.
  3. johnim40
    johnim40 Minimodder
    23 Apr 2009
    thanks
    heres mine so far all folding 24/7 unless gaming rarely
    spare/gaming room
    i5 750 8gb 2 x msi 460gtx cyclone hx520 before
    [​IMG][​IMG]
    i5 750 8gb 2 x msi 460gtx cyclone hx520 tidied up
    [​IMG][​IMG]
    e5200 1gb msi 560gtx ti twin frozr ii hx430
    [​IMG][​IMG]
    pc corner/frontroom
    i5 750 8gb 2 x evga sc 660gtx sli hx520
    [​IMG][​IMG]
    i5 2500k 16gb 2 x zotac 760gtx sli tx750
    [​IMG][​IMG]
  4. DocJonz
    DocJonz Another CPC refugee .....
    24 Apr 2009
  5. johnim40
    johnim40 Minimodder
    23 Apr 2009
    thanks i just copied the post there
  6. Scorpuk
    Scorpuk Minimodder
    10 Jan 2012
    Nice setup John.
    You should run HFM.NET. :D
  7. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    Open case with a desk fan does the trick.
  8. steveneedle
    steveneedle Minimodder
    2 Jan 2010
    I got 2 computers in an outside brick shed...just put a big hole in the wall so I can mount a 200mm fan as an extraction for it....don't want it too noisy for the neighbours
  9. DocJonz
    24 Apr 2009
    Nice! (I considered doing something similar). Presumably these are wirelessly connected to the net?
  10. TaRkA DaHl
    TaRkA DaHl Modder
    15 Mar 2011
    Powerline adapters I suppose.
  11. steveneedle
    2 Jan 2010
    at the moment wireless but im having trouble with speeds and too many others connected wireless to the router....so im gonna get a switch and run a wire out to it....maybe I could get somemore computers then lol
  12. GeorgeStorm
    16 Dec 2008
    Definitely get a cheap switch and some long cables :)
    Cooling wise I'm only folding on a single gpu at the moment (just kind of starting again), and so I just whack up the fan :p
    Noisy (reference GTX570 cooler) but ah well, it's for a good cause :p
  13. steveneedle
    2 Jan 2010
    yea I found a switch for less than £10 in scan so that sounds good to me
  14. johnim40
    johnim40 Minimodder
    23 Apr 2009
    has anyone got a portable air conditioner if so what would you recommend for a sub £100 one
  15. johnim40
    johnim40 Minimodder
    23 Apr 2009
    i got this yesterday room dropped 10c
  16. TaRkA DaHl
    TaRkA DaHl Modder
    15 Mar 2011
    I'd watch the power draw of that! Will make bills go up very quickly :)
  17. kirk46
    kirk46 Cheesecake Nom Nom
    9 Jun 2012
    +1
  18. johnim40
    johnim40 Minimodder
    23 Apr 2009
    850w full load using watt meter
  19. kirk46
    9 Jun 2012
    thats not bad but still ouch lol
    i expected it to be around 2kw
