News Corsair announces Hydro Series H75 dual-fan cooler
Discussion in 'Article Discussion' started by Gareth Halfacree, 25 Oct 2013.
  1. Gareth Halfacree
    4 Dec 2007
  2. Hamfunk
    Hamfunk I AM KROGAN!
    10 Nov 2009
    So it's an H80 then???
  3. Gareth Halfacree
    4 Dec 2007
    No. The H80 has a 38mm-thick radiator which, when the two fans are added, makes it unsuitable for more compact cases; the H75 has a 25mm-thick radiator.
  4. Hamfunk
    10 Nov 2009
    Ahhhh, that makes more sense. Thanks.
  5. Panos
    Panos Minimodder
    18 Oct 2006
    H60 wasnt that good, even compared to H50. And I doubt anyone is around that used only 1 fan with those systems.
    Even the H100 asks for push-pull config, and while is huge, there is space around to put it on on most cases today. (top). And yes I have one (as did a H50) and I know how big it is.
  6. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    The H75 is an H60 with 2 fans instead of one. The price on Scan is about £9 more expensive (£67.98 as opposed to £58.32) so the price seems about right for a matching and included extra fan.
    The thing that bugs me is the name. Using 75 instead of 65 implies to me that it is a better unit than the H60 and yet it is virtually the same except for the fan.
  7. Gareth Halfacree
    4 Dec 2007
    Actually, it isn't: as it says in the article, the radiator is redesigned and slightly thinner. The H60's radiator is 120x152x27mm, the H75's radiator is 120x152x25mm.
  8. SchizoFrog
    5 May 2009
    I need more details to totally agree there. The article says it was redesigned for dual-fan layouts (not sure layout is the correct term to be used there), it doesn't say that the rad itself was redesigned as in the design of the internal fluid chamber. This leads me to believe that the change in thickness is a change to the outer shell of the rad rather than an overall change of design.
    The proof will be in the testing. Many users have added second fans to a H60 so it will be interesting to see what the figures are between an H60 with 2 fans and an H75 as stock. However, I doubt this test will be done here on Bit-Tech as the argument of 'choice of fan and various cost differences' is often used for not doing certain comparisons, such as adding extra fans to cases for example.
  9. Gareth Halfacree
    4 Dec 2007
    You've got as much information as me, there: the radiator is thinner, that's as much as I know.
  10. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    However you dress it up, it's hardly worth getting excited over.
  11. Chicken76
    Chicken76 Minimodder
    10 Nov 2009
    Who will be manufacturing these? CoolIT or Asetek?
  12. Baz
    Baz I work for Corsair
    13 Jan 2005
    It's an asetek model with a re-designed mounting and Corsair Sp-120 fans.
