Scratch Build – In Progress DESK MOD!! Completed! Pictures and videos!!
Discussion in 'Project Logs' started by Tim_Saville, 7 Apr 2013.
  1. Tim_Saville
    Tim_Saville What's a Dremel?
    3 Apr 2013
    This is my first computer mod, i built a desk the house my computer, three fans on the back for cooling and dvd, usb, lights and power on the front.
    The computer
    AMD 6 CORE fx CPU
    MSI 970a - g46 MOBO
    XFX R7770 OC
    Cosair gs700 PSU
    OCZ 120GB SSD
    1TB WD HDD
    8GB cosair vengenace RAM
    The desk has 6 shelves, all created using dowel joints, the same method of construction was used on the box that houses the computer
    The desk is pure 100% Oak, from a local timber yard, legs wany grain, the hole desk has 2 coats of polythene varnish, top has 4 and a layer of beewax
    Here is a couple of pics to give you an overview, building pictures below, Sorry about pics problem, now uploading
    First pictures, everything put together and varnished
  2. Cheapskate
    13 May 2007
    Shortest-log-ever.
    Asouter likes this.
  3. Pranja
    Pranja Blackwolf
    18 Dec 2011
    +1 :hehe:
  4. Father-Time
    Father-Time Minimodder
    23 Feb 2004
    I like it, Minimalist is definitely the way to go! :)
  5. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Eeeuhhh? pics?
  6. Teelzebub
    27 Nov 2009
    Not forgetting the epic picture :hehe:
  7. dream1
    dream1 What's a Dremel?
    26 Feb 2011
    LOL
  8. dream1
    26 Feb 2011
    I hope to see some pic to :)
  9. Ripitup121
    Ripitup121 MMMMMMm watercooling....
    18 Aug 2010
    pics or it didnt happen!!!
  10. Pranja
    Pranja Blackwolf
    18 Dec 2011
    I think it's troll.
  11. Tim_Saville
    3 Apr 2013
    ****, forget about this, pics comming in 2 seconds
  12. The_Crapman
    5 Dec 2011
    FEED THE TROLL
    Asouter likes this.
  13. Tim_Saville
    3 Apr 2013
    Sorry about this folks was having trouble uploading, pics now comming
    The top of the desk, the four bits of wood that make it up
    The top has hiden loose tounges with the wood;
    I routered a slot and create several slats to add extra strength to the top
    The top being glued
    Me marking out the sizes for the glass top
    I drilled 4 holes in each corner, just alittle bit inside the line
  14. dream1
    26 Feb 2011
    Eeeeeem still no pics :p
  15. Tim_Saville
    3 Apr 2013
    Hole cut out for glass using gigsaw, cutting from hole to hole
    Routered a rebate for the glass to sit on, 10mm down and out
    The legs for the shelves
  16. Tim_Saville
    3 Apr 2013
    Cut out the holes for the shelves and dvd, using a frame made on cnc machine and then routered around
    Used same method for fans holes
    Shelves together, doweled together and glued
    Mounting holes for Motherboard, on plate that the computer sit on
    Mounts for SSD AND HHD
    First test of everything once mounted, no cable management atm
    Computer box doweled together
    First test, making sure that the computer fitted in the box
    Placed pine strips around the underneath of the shelves to support the base
    First real look at what the desk would look like
  17. adidan
    25 Mar 2009
    Completed? Wood with pencil marks? I was kind of expecting a bit more, not meaning to be harsh. :)
  18. Tim_Saville
    3 Apr 2013
    Fans glued in
    Placed mdf panneling around the fans to make it look better
    Glued dvd and usb in and placed black ayrillic around it
    Drilled holes for bolts to hold the whole desk together
    Second test after slight cable management
    First actually use of the computer with screen
    Varnishing with polythene varnish
    All front i/o buttons and drives fitted and glued with panneling
  19. Tim_Saville
    3 Apr 2013
    Varnishing legs
    Night time test, lit up room, the leds are really bright
    Asouter likes this.
  20. woody_294
    woody_294 Wizard Ninja :P
    31 Dec 2008
    Very nice desk, the kit could do with some tidying up though, maybe some cable management and a little bit of positioning to show off the parts more :)
