Case Mod - In Progress Project Honor[Complete]
Discussion in 'Project Logs' started by WanV, 18 Mar 2017.
  1. WanV
    WanV What's a Dremel?
    23 Dec 2016
    Hi,This is my second case mod
    For this time i try to mod based on For Honor Games
    Before That i would really like to thank you to all those sponsor and trust for my case mod and first sponsored project
    Thermaltake = http://www.thermaltakeusa.com/
    ADATA =http://www.adata.com
    XPG From ADATA =http://www.xpg.com/en/
    Here the Spec For This Case Mod
    Thermaltake:
    Core X71
    P1 Pacific Black Pump
    Pacific Flow Indicator
    R240 Radiator
    Pacific W3 Water Block
    Pacific V-GTX10 Series
    TT Sleeve Mod Cable Pack
    Commander F6 RGB
    Toughpower Grand RGB Series 750
    TT PREMIUM FAN 3 PACK RGB
    V Tubler PETG TUBE 16mm
    Thermaltake Bending KIt
    Thermaltake Yellow And Black Coolant
    Some TT Fitting 90 Degree Dual OD,Compression Fitting,Angle Fitting,And Extender
    From Adata
    XPG Z1 DDR4 3000MHZ 16GB KIT
    SU800 AND XPG930 SSD
    Other parts
    Intel Core i7 7700K
    Asrock H270 Performance
    Design
    i've never been good for 3d such as sketchup or anything like that so i can only my design by my work in real life
    Thanks
  2. GeorgeK
    18 Sep 2010
    Hello and welcome to the forums
    Can you please edit your first post to resize your images (hit the edit button at the bottom of the first post). When using imgur you need to select the large thumbnail option otherwise your pictures show full size as our forum does not resize images for you.
    Thanks
    GK
  3. WanV
    23 Dec 2016
    hi sorry for inconvenience will do ASAP
  4. WanV
    23 Dec 2016
    my first work is measuring case size for side,front and motherboard tray since i try to custom all the part
    core x71 i think can fit 420 rad but im going to use 240 rad only
    measuring top panel thinking to create custom top with acrylic material
    i think im going to let it maintain with stock look for back io panel
    since i dont want to risk any motherboard im using biostar tpower i45 motherboard to measure tray and offset for my part
    i think can fit 2 330ml reservoir but im going to use 220 res only
  5. WanV
    23 Dec 2016
    Front Panel part which i cut with laser cut machine
    Done cut with laser and now assembly some part to see which 1 missing
    top panel which i trace with laser and need to remove 1 by 1 before spray
  6. WanV
    23 Dec 2016
    remove all standard fan which came with x71
    front panel switch button,its easy to remove only 2 screw used to mount it
    cutting front panel because i will fully custom with it only need the frame
  7. WanV
    23 Dec 2016
    sanding frame and side panel with orbital sanding 320grit
    [​IMG].
    wet sanding with 800 grit to get smoother finish
    using tack cloth to remove all dust,oil
  8. WanV
    23 Dec 2016
    Case Mod Project Honor[COMPLETE]
    ready my acrylic part
    my spray gear and paint
    using alloy red paint
  9. WanV
    23 Dec 2016
    undercoat silver to get the colour right
    thinning the paint to 2:1 ratio with thinner
    Undercoat Process for all part
    Frame
    Side Panel 1
    Bottom Panel/Rad Panel
    Pcie Slot
    Front Panel Acrylic
  10. WanV
    23 Dec 2016
    done spray red alloy colour for frame
    not really good finishing i hope i got a room for spray
    front panel part
    pcie slot with pearl gold
  11. WanV
    23 Dec 2016
    Finish Part
    Top part
    Front Panel
    now i start to knit front panel with hemp cord
    slowly progress
    half done
    done tighten all rope
  12. WanV
    23 Dec 2016
    Done front panel
    inside front panel
    inside ssd box
  13. WanV
    23 Dec 2016
    Thank to asrock for this nice motherboard
    H270 performance
    it look fancy eventhough its just H series
  14. WanV
    23 Dec 2016
    my custom reservoir stand based on samurai sword stand
  15. Weekly_Estimate
    Weekly_Estimate Random bird noises.
    1 Feb 2010
    Love this! keep it up!
  16. WanV
    23 Dec 2016
    thanks, by the end of next week i hope can finish this build
  17. WanV
    23 Dec 2016
    start doing wc stuff
    going to place pump at top instead bottom part
    done assembly thermaltake w3 cpu waterblock and i can see from this image that somepart got bad mark since im using glue to fix it
    some tt fitting still thinking which way should i do
    drilling 4 hole for radiator loop
    quite tight spot to get good bend eventhough i can use soft tubing but i go hard tubing all the way
    done fitting 2 radiator for both way
    will be using tt flow indicator..i just hope tt got transparent flow indicator because when mix with dark colour coolant i cant see the flow anymore
    loop to go to radiator
    done doing my loop.now im going to leak test for 2-3 hours
  18. WanV
    23 Dec 2016
    Im done with my build i hope all of you can give honest opinion for my case mod
    sponsor for my case mod XPG by adata,Asrock,Thermaltake
  19. WanV
    23 Dec 2016
    Top Panel
    Interior
    Radiator Cover
  20. WanV
    23 Dec 2016
    Temp Reader with power button
    SSD Box
