Motherboards maximus III forlmula audio problems
Discussion in 'Hardware' started by bagman, 30 Apr 2010.
  1. bagman
    bagman Minimodder
    18 Apr 2009
    hi guys need some advice i think the sound card which came with board has broken
    it worked fine when i first got i installed the drivers and it worked fine but now it seems it is completley dead as not even the blue wrighting on the sign turns on but the sound card for my maximus formula does glow but having problems with drivers
    so what should i do?
    should i contact asus?
    thanks
  2. Judge Zetsumei
    Judge Zetsumei What's a Dremel?
    8 May 2009
    All I can suggest is the obvious really, make sure it's in the slot properly and if it is then RMA the motherboard. I had to RMA mine once but that's because it fried lol.
  3. bagman
    bagman Minimodder
    18 Apr 2009
    i might just keep my board and just buy a good sound card i have always wanted one and now seems the ideal time
    but thanks for the sudjestion
