Watercooling need advice on water cooling a cooler master cm690 nvidia edition case
Discussion in 'Hardware' started by Chriscogley, 23 Aug 2011.
  1. Chriscogley
    Chriscogley What's a Dremel?
    13 Jul 2011
    please help:duh: i wanna water cool my cpu and gpu but need to know if there anything i can use as it not water cooled as standard:confused:
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    You could've just used your other thread :p What's your budget?
  3. Bede
    Bede Minimodder
    30 Sep 2007
    Eww why the nvidia edition? Extra branding =/= cool.
    You can stick a small 240mm rad in the top and another in the bottom (if you remove the lower hdd cage), should be sufficient for cooling a sensible set-up.
  4. Chriscogley
    13 Jul 2011
    not huge but all suggestions are welcome no matter on cost
    my bad i thought i had to start a new one to ask a new question im new to this site
    sorry
  5. Bloody_Pete
    11 Aug 2008
    We prefer not too really, saves on clutter :p Whats your system spec buddy?
  6. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    If you can fit a 240 rad then what about the corsair h100.
  7. Chriscogley
    13 Jul 2011
    it is for a new build but look at bede's setup mine gonna be the same near enough
  8. Bloody_Pete
    11 Aug 2008
    Its the GPU that's the main heat producer, so same GPU?
  9. penryn 2 hertz
    penryn 2 hertz I'm not a science fiction writer...
    10 Jun 2010
    I am going for cm690 but in white i plan to put a thick 240 rad at the bottom and a slim 240 at the top with a ek 800l/h pump...
  10. Bloody_Pete
    11 Aug 2008
    I know 23RO_UK did a build in one but I can't find the thread any where :(
  11. Bede
    Bede Minimodder
    30 Sep 2007
    That's basically my plan if I ever go watercooled. Thick for the GPU and thin for the CPU. I'm not sure about where I'd mount the pump/reservoir though.
  12. Guest-56605
    Guest-56605 Guest
  13. Bloody_Pete
    11 Aug 2008
  14. Guest-56605
    Guest-56605 Guest
    I think build logs disappear from the listings if no posts are made to the thread after a given period of time Pete, they aren't deleted; if you go to the persons profile and look at the threads they've started you can normally find them that way :thumb:
  15. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
  16. bulldogjeff
    2 Mar 2010
  17. Chriscogley
    13 Jul 2011
    23RO_UK you f**king animal thats is an insane build that you have done
    do you mind if i use the same idea please mate?
    thankyou all for all of your advice i only joined recently but i am already loving it on here
    thankyou all :)
  18. Bloody_Pete
    11 Aug 2008
    I'm sure he wont mind, he's focussed on other things now :p
  19. Chriscogley
    13 Jul 2011
    dont wanna copy his parts just the idea of the top and bottom rads that's all
  20. bulldogjeff
    2 Mar 2010
    Paul's a really friendly bloke, he'll help you along all the way if need be.
