right, I've been searching all over the place but I'm not getting much luck. I'm after some Superflux LEDs in Amber, white and probably Red. I can find them on eBay from China, but I was wondering if anyone had a good cheap source in the UK. I had a look on the electronics FAQ page but a load of the links are out of date and don't take me anywhere useful. Anyone have any good links. I would get from Farnell etc but they are expensive. Thanks. -J
Worth checking aliexpress.com as you'll likely be able to buy them direct from the suppliers and cheaper than on eBay.
Yeah I found a great supplier of high power cree LEDs on there. Made a killing selling them on eBay a couple of years ago. Just be sure to pay on a credit card so you can claim back the money if things do go wrong.
have you checked http://www.phenoptix.com? There is gold-yellow in selection. You can always ask if they can get amber for you in stock?
credit card? I question most decisions involving credit. The fiends who made those are the next closest thing to con-men Not to doubt you, just credit Though i may look at that site as well. Was about to ask the same question till I saw this thread!
No doubt there are differences between the UK and the US when it comes to them, I pay mine off in full every month so there's no extra cost than paying from a debit card. It's just a safer way to buy online as you can claim the money back for purchases should anything go wrong, the CC issuer takes the risk.
