Windows Reinstalling windows but with problems
Discussion in 'Software' started by Tigernos, 16 Apr 2012.
  1. Tigernos
    Tigernos Resident Roman Soldier
    12 Dec 2011
    So my laptop has some issues, mainly with the fact that the 300gb HD is nearly full and I have no idea what its full OF. Its also booting slower than my desktop with XP on it. (That might be normal but I'm a newbie)
    So, I want to clean it off and give it a fresh start with Win7 64bit. I don't have a disc but I know you get get ISOs for that BUT the key on the sticker conveniently affixed to the bottom of the laptop has been rubbed mostly illegible by having been sat on my lap (fancy that with a laptop)
    Is there any way to find out the CD key aside from my now useless piece of adhesive and paper?
  2. Pookeyhead
    30 Jan 2004
  3. Tigernos
    12 Dec 2011
    I assumed anything called magical jelly bean would be a troll. But I guess I'll try it.
    If it breaks my laptop I'll hunt you down and smash your Earth server while your Moon is down... muhuhahahaha
  4. Fire Strike
    Fire Strike What's a Dremel?
    27 May 2010
    Can you not just right click "Computer" in the start menu, got down to "properties" and then at the bottom of that page should be your activation status and your current product key.
  5. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    it won't break your laptop. I've used it long time.
  6. Tigernos
    12 Dec 2011
    Nope, there is a number there but its a load of digits with "OEM" then another few digits, it bears no resemblance to what is still legible on the key sticker.
  7. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
  8. DeafGamer2015
    DeafGamer2015 Minimodder
    5 Jun 2010
    use the magical jelly bean program.. I heard it's quite good.. it doesn't hurt your computer.. it'll bring you the information you need to reinstall your Windows..
  9. GoodBytes
    20 Jan 2007
    This only works for Windows Vista/7 Ultimate, edition (maybe also 8, we will have to see once the editions are set, and of course that the OS is finished development)
    Arrg, I hate laptops that puts the product key at the bottom of the system. I think the best spot, is where Dell Business class system puts it, UNDER the battery compartment. So basically, if you remove the battery, the label is on the system. This way the laptop is protected by the battery, and also you have a nicer, cleaner looking system.
  10. lysaer
    lysaer Suck my unit! Kirk lazarus (2008)
    15 May 2010
    Just install windows 8 imo
    Sent from my HTC Sensation 4G with Beats Audio using Tapatalk 2
  11. Pookeyhead
    30 Jan 2004
    LOL.. you've nothing to lose if you were re-installing windows anyway.
    Moon is up again. I had a brand new WD EARS drive ready and waiting.. no flies on me! There's a hot spare installed in Earth too.. ready to kick in should it decide to throw a hissy fit too :) The broken drive is already RMAd to WD... new one on its way via courier ready to sit in the cupboard waiting should this happen again.
  12. 3lusive
    3lusive Minimodder
    5 Feb 2011
    What about speccy? Just install that and click operating system and it will show your serial number.
  13. Tigernos
    12 Dec 2011
    Sadly this number also doesn't match what is left of the license sticker. I've only got the first set of digits still eligible but that serial doesn't match them either.
  14. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Serial number and license key are two different entities. I've used Magic Jelly Bean on loads of computers and it does exactly what it says, finds keys. The paid for version also finds other keys apart from Windows.
  15. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    This. As others have said, Magic Jell Bean is great. You can even change your product key with it.
  16. tony007
    tony007 What's a Dremel?
    9 Feb 2011
  17. GeorgeK
    18 Sep 2010
    Also - before you go ahead and reinstall windows you could try windirstat to find out what your hard drive is full of and / or run ccleaner to try to clear some junk - even if it's just to reduce your backup size before you reinstall
    GK
  18. Tigernos
    12 Dec 2011
    I'll give tht a try. I use ccleaner regularly. I suspect it's a few movies or tv shows I've downloaded and theyre kicking around the drive somewhere obscure. The thing is due for a proper clean out anyway. Anything I want/need is already backed up so I just wanna wipe it and start from zero.
  19. Fat Tony
    Fat Tony Minimodder
    3 Jul 2009
    Another vote for the Magic Jelly Bean
  20. short1uk
    short1uk Minimodder
    20 Sep 2011
    With the key worn off the OEM key (one used to install the OS) wont work with a Win7 disk - have tried this. What you need is a disk from the laptop manufacturer. What make is the laptop? These sometime dont need activating as they detect its the right disk for the right machine.
    First thing I do when setting up new machines is put cello tape over the product key!
