Other Turion CPU driver
Discussion in 'Software' started by wufer, 21 Aug 2015.
  1. wufer
    wufer What's a Dremel?
    18 Nov 2011
    I have a Dell Latitude 131L, with a 'Mobile AMD Sampron 3500+' cpu.
    I want to replace the Sempron with a 'AMD Turion 64 x2 TL-50' CPU.
    I understand they are both Socket S1, so the new cpu should fit.
    But what i cant understand is how do i get the driver for the Turion.
    Will the driver come when i fit the Turion, or will i have to download it somehow.
    The reason i want to change the cpu's is, the Sempron is much to slow to run Windows 7,
    and i know the Turion will run it fine.
    Its just the driver thats got me thinking.:wallbash::wallbash:
    Cheers
    PS. I dont have the driver disc/
  2. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    What driver? CPUs don't have drivers.
  3. RedFlames
    23 Apr 2009
    What Cerberus said, The CPU doesn't have a 'driver'...
    As long as the laptop's bios supports the CPU, which it should as iirc the TL-50 was an option on that laptop, you'll be fine...
    Whether it's worth the effort is another matter entirely, the Turion range weren't that great a even when new. You'll probably find it'll still bog down with W7, just not as badly as the [single-core iirc] sempron.
    phuzz likes this.
  4. wufer
    18 Nov 2011
    Cheers
    No driver , well that shows how much i know:sigh:
    Windows7 should run ok on a Turion.
    A friend has the same set up , and as a family laptop, it runs fine.
    Laters
  5. phuzz
    phuzz This is a title
    28 May 2004
    (It's really nice to see that BitTech is still a place where you can ask a stupid* question and get a sensible answer)
    *[no offence wufer ;)]
  6. wufer
    18 Nov 2011
    No offence taken:D.
    A wise old Chinaman once told me. "There are no stupid questions...only stupid answers"
    Ha so:D
