Here's what I'm trying to do: http://imageshack.us/photo/my-images/684/rightpanel2.jpg Need to fix the perforated alu inside my case panel, but not having much look.. There's tape on the back, and have tried covering the opposite side with JB weld, but even with some weights on top the alu is never even on all sides. Don't have any clamps I could use either so I guess not much else I can try :/ Appreciate any help!
Just use some two part epoxy. You can get the five minute stuff so it doesn't have to be held for long. I use it for alu and stainless mesh to alu. Sets rock hard and doesn't budge. Edit., Make sure you sand the paint off where you are gluing.
Well JB is suppose to be the 'best' but I guess I'll buy something else instead then, hopefully that helps - Thanks!
