Parvum Extreme MbK Sponsored by: Hi fellow casemodders, Kier is back...again This time I will start with a great new acrylic case Probably you have seen it allready in the buildlogs from L3p and K.3nny, the new Parvum systems S1.0 The case is individually cut and hand assembled, various colors and custom modifications possible When unpacking I noticed the very good quality acrylic (5mm high quality acrylic) ... very hard material to work with, but not impossible, more on this later. The layout is also beautifully engineered. The case is available from mid-March @ Highflow Parvum Systems S1.0 White And @ http://www.overclockers.co.uk/showproduct.php?prodid=CA-000-PS How it all started: After missing the postman two times it finally happened. A BIG package: Very well packed Hmm 2??? yes 2 Want to build something extreme. My kid really would like to know what it contains and whether it is for him .... unfortunately for him, these are for me Little picture with it from the two cases stacked. And a warning just in case ... A nice thank you letter from the Parvum family The black and white case with the following specifications: - Materials: Acrylic - Colours: Black/White - Dimensions (WxHxD): 275 x 305 x 420mm - Maximum CPU Cooler Height: 152mm - Motherboard Sizes: mATX - 3.5" Drive Bays: 2 - 2.5" Drive Bays: 4 - Cooling Front: 2 x 120mm - Cooling Rear: 3 x 80mm - Cooling Top: 2 x 120mm - PCI Slots: x 4 4x PCI slots PSU opening Air outlet for the PSU Front fanholes And more 80mm fanholes at the back The mATX mobo tray, a hand bent acrylic mid-wall. Provides both case strength and the cable management With openings for the cables and possibly tubes The second case is slightly different internally and externally then the first original. Because I'm planning some fun stuff with this However, both with window Front is the same Furthermore the second case is empty, because I need only 1 hardware section. It is also slightly different at the back. 2x 120mm fanholes in the middle Also there were some nice extras in the package like: Case feets Some beautiful 240mm radgrills. And a 160mm radgrill. I also asked for some extra rest material for various purposes. Extra mounting stuff. Some last shots of the cases together To be continued
Every one is doing Parvum. Cool to follow how different those cases will be. will be following this one.
I'm new to this site, but have been following your work Kier. Looking forward to see what your skills can do with this rather tasty case......
Update Sponsored by: Thanks for the comments... and now modding time The idea is to stack everything. The bottom with the hardware, then the radiators and on top the reservoirs So Rads + fans on the original part of the Parvum To reinforce the lower part a bit i've placed some aluminum strips. Just to be sure Used the existing cubes to mount the next layer. On each corner Cut some side panels to the right size and an opening for the fans Like this And cut two pieces black and white. Black has the same same shape as the original front below. In this there will come an Asus ROG logo Placed the radiators. Still need to make brackets for these Also placed the fans Looks good allready I think ROG logo will be added later For the back I have cut 2 panels with fanholes to the right size And placed it Testing the fans and gives me a nice shot And we continue with the next layer These will be all around with windows except the back. It will be the same height as the radiator layer.
Update Sponsored by: This weekend received some great products for the build of Parvum from EKWB Thanks Niko, 2x EK Coolstream XT 360 2 beautiful EK-RES X3 250 Some extra EK-RES X3 - Multiport TOPs And EK-RES X3 - TOPs to try something out Also some nice EK-FC7870 Nickel plexi water blocks And offcourse the EK-FC7870 black backplates Next update coming right up
Update Sponsored by: So my modding friends time to end this Easter weekend with a big update. Asus also joined the party for this build. And they have send me a great motherboard. Btw. I have expanded my photo gear so the pictures will look like a bit different than normal The Asus Maximus V Gene The accessoreis: And the beautifull motherboard •LGA1155 socket for 3rd generation Intel® Core™ processor-based platform and 2nd Generation Core™ i7/ i5/ i3/ Pentium® / Celeron® Processors •Intel® Z77 Express Chipset •SupremeFX III - Supreme Sound •GameFirst / Intel Gb LAN – Frag Without Lag •mPCIe Combo – Give Your PC A Power Up! •NIVIDIA® SLI™ / AMD CrossFireX™ Technology Support •LucidLogix Virtu MVP - Up to 60% Hybrid Graphics Boost Thanks Sven Also placed the EKWB EK-FC7870 onto the GPU's. Placed the nice FC7870 backplates Time for some modding. Om top of the Parvum I placed the resevoirs, with here and there some acrylic tubes The outlets The inlets and one of the fill ports Everything straight And a total shot Placed top and mobo Installed the EK-Supremacy. Did some brainstorming for the tubes CPU outlet to the GPU inlet Then go right Placed the pump about as posted on the HDD cage, more about this later To hide the HDD/ SSD I have cut some acrylic. Also filed and polished Glued together with ACRIFIX Just a few more. Placed the pump onto the last plate. This week I will receive the last panels for the top after this it's time to do some last things sleeving and connect all the tubes. Grtz.
Jeesus effin' christ kier! How many can you do at once in a row before you blow up your dremel?! Havent even a chance to read the log yet but I have faith in your skills!
Thanks Love the case mate Thank you....No, they are NorthQ fans Thanks Nate Again one of your favorites? Lol, i have more then one Dremel
KIER!! This is ridiculous.. I was just talking to a guy about the ALX and now this.. My goodness!?!? You probably have a backlog of companies just begging you to build something with their parts!! If only I had the time...
