PPD tailing off
Discussion in 'bit-tech Folding Team' started by HoistaWheelie, 20 Jun 2009.
  1. HoistaWheelie
    HoistaWheelie Slow but steady
    23 May 2009
    Is it just me or is everyone noticing their PPD average decreasing over the last few days ?
    I was consistently getting between 10K and 14K per day, then all of a sudden the PPD nose dive :jawdrop: and that's despite me adding an extra GPU (lowly Quadro NVS 290) ...
    06.20.09 - 5,068
    06.19.09 - 4,756
    06.18.09 - 9,714
    06.17.09 - 9,894
    06.16.09 - 11,801
    06.15.09 - 10,354
    06.14.09 - 10,655
    06.13.09 - 14,853
    Only change I made was to convert two PCs to Windows 7 ?
    Bemused of Dorset :sigh:
  2. Vince_Kinslow
    Vince_Kinslow Folding Millionaire
    25 Apr 2009
    I Have been folding with a 295 and Windows 7 RC very disappointed with the PPD but you will also find that if you get the dreaded 511 pointers they drag your PPD down no end.
    Not sure if mthere are some optimisation issues for the clients in W7RC no Guru
    Like the eye candy element of W7RC but the performance is nowhere as good as XP Pro IMHO
    Things seem so much easier to set up in XP and its no where near as resource hungry.
  3. Christopher N. Lew
    Christopher N. Lew Folding in memory of my father
    23 Apr 2009
    Almost certainly the change in OS is the main source of your decreased production; almost everything involved, drivers, clients etc. have not been optimised for Window 7 yet.
    Although 511 point projects do score low, I have been getting a good mix of WUs over the past day.
  4. chin913
    chin913 忍び So say we all
    26 Apr 2009
    Thats all ive had is the dreaded 511 pointers past few days its killing my ppd :-( i just thought I had major problems @1st
  5. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    Most peoples PPD will go up and down depending on projects downloaded.
    If I get 511 projects on all my GPU's which happens a few times a week then FahMon drops 10k ppd!
    What does your daily average ppd as thats the one to go by day to day :)
  6. HoistaWheelie
    23 May 2009
    511 pointers ...
    Hmm okay back to 10,250 yesterday so must have been a couple of days of only getting 511 point WU ...
    Just picked up a fully working dual core DELL Precision Workstation (£67) and a 9800GT (£60)for 24/7 folding :thumb: so hopefully 15K PPD soon!
  7. chin913
    26 Apr 2009
    What I cant understand is that my fahmon say's I should be putting out at least 18k yet I look @my stats and its shows a crappy score of 13,952k . I thought I could have had the team no wrong on one of them but they all seem ok so I am @ loss to whats happening .Is fahmon wrong in the info thats it's showing
  8. Vince_Kinslow
    25 Apr 2009
    As has been Posted under a seperate thread Fahmon basis your PPD on the current work units you are processing it will vary greatly due to the different work units you fold. Dont panic :cooldude:
  9. Christopher N. Lew
    23 Apr 2009
    Stats lag, sometimes by more than 24 hours. You make a change on your machine, which Fahmon will react to quickly, but then the machine has to finish the unit, Stanford servers have to process the completed unit, which takes time because of the queue of returned results, then Stanford Stats only update every 3 hours, and EO stats only update from the Stanford Stats every 3 hours. There are probably other processes going on.
    Don't panic.
  10. chin913
    26 Apr 2009
    No wonder I had some low points bloody peer guardian was blocking some of my units one had 7 waiting 2 upload maybey i should have taken more notice .....:wallbash:
  11. Christopher N. Lew
    23 Apr 2009
