Build Advice Budget Gaming PC for £250?
Discussion in 'Hardware' started by Dean R, 6 Feb 2013.
  1. Dean R
    Dean R What's a Dremel?
    18 Feb 2010
    A friend at work wants me to upgrade her PC for £250 max for her grandson.
    She only uses it for Office and web browsing but wants it for her grandson to play games on. I told her it would be difficult for that kind of price but I would give it a go.
    She has given me her Dell Dimension E520 to upgrade or sell on ebay to put towards a new build.
    Was looking to build a i3 based system but its looking tough at that price.
    Also, not quite sure what condition this Dell is in yet and whether anything is salvageable.
    Basically wondering if anyone out there could recommend a possible build for me? £250 has to include postage from Scan.
  2. Strudul
    Strudul ~
    31 May 2010
    You should have free delivery from Scan if you link your BT account.
  3. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    Can you keep the HDD and Monitor, Keyboard, Mouse, and Case?
  4. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    Would be looking at used parts with that budget if the old system cant be upgraded.
    PSU will be crap for a start.
  5. Dean R
    18 Feb 2010
    HDD is busted apparently. Not got my hands on the PC yet so dunno for definite. She doesnt need a monitor. I can use anything theyve given me so drives and stuff yes.
  6. Dean R
    18 Feb 2010
    Didnt know that thanks. Always tried signing up with AV forums but you have to be active now,
  7. Nealieboyee
    14 Aug 2009
    This is a good start. People will tell you to go for the i3, but its not necessary. Still needs a hard drive though. What cpu does the Dell Dimension have?
  8. Harlequin
    Harlequin Modder
    4 Jun 2004
    ebuyer have complete systems for that budget , not the most awesome but should do teh job
  9. Nealieboyee
    14 Aug 2009
    Yeah but I wouldn't trust the PSU's in those systems, at least not for gaming with a dedicated gpu
  10. Harlequin
    Harlequin Modder
    4 Jun 2004
    true, they seem to be 300w ; but for your list your missing a hdd as well (op said it was busted) so thats another £40 on top , so that £250 machine is kncking on 300 :(
  11. Nealieboyee
    14 Aug 2009
    Yeah I got the list together before I saw the "hdd is busted" part. But if he sells the parts from the Dell Dimension, he should be able to afford a new HDD, hopefully. It depends what cpu that system has. He can sell a core 2 duo quite easily, but Pentium 4's are worth nothing these days.
  12. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    Operating system?
  13. rollo
    rollo Modder
    16 May 2008
    Decent question that from modd1uk if it has no operating system this budget is way too small. Borderline impossible tbh.
    Depends totally whats in the dell dimension as there will be no OS disk. If the HD is busted theres £40 that you have to find also.
    If it has a core 2 duo he could use it instead of buying a cpu its still a more than capable gaming cpu.
    You may be better off heading the AMD route with there intergrated graphics been good enough for most basic games assuming the resolution is not pushed too high.
  14. David
    7 Apr 2009
    Probably gunna need a new case - the layout of those Dell boxes is usually proprietary.
    YEHBABY likes this.
  15. Harlequin
    Harlequin Modder
    4 Jun 2004
    rebuilding it if its a C2D would be feasible - but not if its a P4D
  16. atc95
    atc95 I have the upgrade bug!
    3 Dec 2012
    What about ditching the gpu and use trinity e.g. A10 5700, it won't be an incredible gaming machine but judging by op, gaming is the 2nd purpose.
  17. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Depends a lot on how old is the grandson, and what do they mean by games. Stuff like plants vs zombies or BF3... if the former it's quite easy, if the latter forget it. That budget is too small to have a good expierience with much beyond casual unless you get a lot of luck in the used market. Even still its a stretch and if you need a legit Windows, it's impossible as it's what a 1/3 the budget?
  18. Nealieboyee
    14 Aug 2009
    Too much negativity here lol. He can do it! More info would be great though, such as monitor resolution, games list (as mentioned before), and Windows version.
    Also, can you buy second hand?
  19. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
  20. Nealieboyee
    14 Aug 2009
    You're kidding right?
