Slow server
Discussion in 'Feedback & Suggestions' started by RTT, 4 Apr 2014.
  1. RTT
    RTT #parp
    12 Mar 2001
    I'm guessing this isn't just me - dynamic forum pages are very slow (static assets are fine and dandy, which points to some backend issue). Figured the new sysadmins ought to know. 3-4 seconds waiting before the page begins to be delivered. 8 seconds alone to load this newthread page :(
    Code:
    >  ~  time curl -s -o /dev/null forums.bit-tech.net
    curl -s -o /dev/null forums.bit-tech.net  0.01s user 0.01s system 0% cpu 9.669 total
    And I'm on a monster net connection only 4 hops from the actual server, so it aint me, guv ;)
  2. RedFlames
    23 Apr 2009
    Forum's chugging for me as well, occasionally spits it's dummy out with a Bad Gateway error too... Plus a there's been a spate of double-posting since the switchover...
    Maybe the new hamsters haven't been fed enough...
  3. Kronos
    Kronos Multimodder
    6 Nov 2009
    Very slow to post particulrly on the tablet but also via desktop but not quite as bad.
    Hopefully the gremlins will be found and dealt with.
    But compared to the PCAvisor forum pages where gremlins are considered justified because the site is 'free' Bit-Tech has always been relatively poblem free.
  4. Teelzebub
    27 Nov 2009
    Yea I noticed this a few days ago.
    @ RTT you're no longer Red
  5. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    It's getting worse
  6. stevekez
    stevekez sysadmin Administrator
    2 Apr 2014
    Hi,
    Yes, things aren't quite perfect right now. I'm tuning what I can, but also need to do some instrumentation that can't happen instantly.
    So, bear with us! And know that I'm kept aware of these problems by the monitoring software, when the servers feel the need to tell me "um, steve, gimme a break!"
  7. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    Come back, Rich, we need you. See if you can find Jamie at the same time ;)
  8. stevekez
    2 Apr 2014
    Things, hopefully, are a little better now.
  9. G0UDG
    G0UDG helping others costs nothing
    27 Mar 2010
    No its still slow and the home page isn't working right either
  10. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    Getting better on my side of the pond.
    Still need to fix the favicon.ico thing one of these days though.
    Not sure why it's bugging me, but it is :worried:
  11. sniperdude
    sniperdude Minimodder
    8 Sep 2010
    Much slower than normal.
  12. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Nope, still slow, and also getting bad gateway errors.
  13. Kovoet
    26 Aug 2009
    Yep just got that too
  14. bulldogjeff
    2 Mar 2010
    Too add to this, it's slow, gateway errors and unable to link pics in threads like normal
  15. Unicorn
    25 Jul 2006
    Same for me at the moment. I have been noticing this most when updating my "participated threads" page in Tapatalk - the update took well over a minute about an hour ago (23:00 DST). I miss the usual red names more than ever now as well. Yoda, Jamie, Tim, RTT and Nexxo to name but a few :( If Krikkit disappears into regular blueness now, I quit.
  16. aramil
    aramil One does not simply upgrade Forums
    10 Jul 2012
    to add to the mix:
    computer: very slow (several browsers)
    tapatalk mobile: nice and fast (wifi) just started to get slower.............
    mobile browser: slow
  17. aramil
    10 Jul 2012
    double post........ (computer)
  18. Teelzebub
    27 Nov 2009
    Very slow and bad gateway error 502 now
  19. RedFlames
    23 Apr 2009
    Nope, need to give the hamsters more coffee, as others have said above, if any thing it's worse than before...
  20. stevekez
    2 Apr 2014
    Alrighty, I've spent most of this evening trying to improve the situation.
    It's still not perfect, as the there are some things I simply can't make use of just yet.
    Let me know how performance is over the next few hours.
    ninjaedit: Some of the 502s are caused by me updating the config, creating a run on a server with cold caches. So I would ignore anything you've seen performance-wise up to 1am BST when evaluating things going forward.
