Scratch Build – In Progress Camouflage Vehicle - COMPLETED
Discussion in 'Project Logs' started by musaad, 15 Jul 2014.
  1. musaad
    musaad What's a Dremel?
    31 May 2014
    Hi,
    This is my first post here. I want you to excuse my English as it's not perfect.
    I have some hardware and water cooling laying around for testing purpose. I decided to build a simple case for those parts.. But when my eyes saw these giant tires from RC truck.. The idea started shining in my head..
    Starting with rims..
    For the chassis, I cut two pieces of 6mm MDF.. and I made holes for cable management and to hold the vehicle body later on.
    I used my router to make room for tires column so it can easily fit between the two pieces of wood..
    Testing the motherboard positioning after installing the tires..
    To be continued ​
  2. musaad
    31 May 2014
    OK.. For the hardware I'm installing..
    CPU : i7 2600k
    Mobo : MSI H61-E35 V2 Mini ITX
    Ram : Kingston HyperX blu
    GPU : Gigabyte HD 7750
    PSU : Silverstone 450Watt SFX
    SSD : AData 256GB
    As I mentioned before, I'm keeping these parts for testing purpose only..
    For the water cooling parts
    CPU Block : EK-Supreme LTX - Nickel
    Rad : EK-CoolStream RAD XTC (140)
    Pump and Res. : EK-Reservoir Combo DCP 2.2
    Acrylic pipes
    SLI fittings from Bitspower
    After removing rad's old paint..
    Preparing parts for new paint..
    For the vehicle body.. I used these cheap PVC pipes..
    After drawing the design and bending some pipes with my heat gun.. It came out like this.. Weird at the beginning , but I'm sure you gonna like it after painting..
    For the paint job.. I used spray paint and I chose White, Black, and the famous Camouflage colour.
    Here. I cut some papers randomly for Camouflage patterns.
    And now for the results..
    Rad fan and SSD..
    Made the connection plug for the PSU.. I placed it in the rear left corner until I decided to move it to the centre, under the rear bumper.
    To be continued​
  3. musaad
    31 May 2014
    I bought some 3mm plexi glass sheets.. I bended one of them and install it as sun roof.. Also I installed the front and rear bumpers, front and rear lights and painted the video card fan..
    Unfortunately, I didn't take pics for these.. But here are the final pics after everything is set..
    SSD
    Power-on button..
    DONE :thumb:
  4. musaad
    31 May 2014
    up...
  5. Craig_T
    Craig_T What's a Dremel?
    2 Aug 2014
    This is great. A good idea and nice work to complete it!
  6. silk186
    silk186 Derp
    1 Dec 2014
    One of the most creative mods I have seen in a long time. What will you do about dust?
  7. Cheapskate
    13 May 2007
    Nice and crazy! Just the way we like it.:thumb:
  8. Del.irious
    Del.irious What's a Dremel?
    6 Mar 2012
    I thought you were suppose to post pictures of computer parts and a mod, but instead it was just pictures of a floor/wall.
    On a more serious note, well done!
