Graphics GTX 580 Configurations
Discussion in 'Hardware' started by Rai, 1 Jul 2011.
  1. Rai
    Rai What's a Dremel?
    22 Jun 2011
  2. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    In a word, no.
  3. jakobfrimmel
    jakobfrimmel What's a Dremel?
    2 Jan 2011
    depends on the resolution your playing at.....
  4. [ZiiP] NaloaC
    [ZiiP] NaloaC Multimodder
    9 May 2008
    I was actually looking at this the other day.
    The 3GB version from EVGA is only €409, whereas if I was to buy a 1.5GB 580 from Ireland or England, it would be €450 or more :D
  5. Deders
    Deders Modder
    14 Nov 2010
    It would help if you wanted a tri-screen gaming setup but be careful to check the clock speeds, sometimes cards with more ram are run at much slower speeds.
  6. [ZiiP] NaloaC
    9 May 2008
    The EVGA card with 3GB has the exact same clock speeds as the "baseline" 580 :)
  7. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    unless your using massive resolutions, i.e. 2560 x 1600, or triple HD resolution, then basically no, the 1.5Gb card is fine
  8. Zehetmayr
    Zehetmayr Minimodder
    23 Apr 2011
  9. Pete J
    Pete J Employed scum
    28 Sep 2009
    This.
    1.5GB has been fine so far for 2560x1600, the only exception being Crysis Warhead with true_gamer's autoexec applied!
    Having said that, I'd have picked up the 3GB version if it had been available at launch.
  10. philheckler
    philheckler Used to be a pc enthusiast
    23 Apr 2009
    The latest dx11 and texture mods for crysis2 eat up 1250mb of gpu memory on my gtx470 at 1680x1050 res - if i was buying a 580 today i'd pick up the 3gb version.
  11. Bede
    Bede Minimodder
    30 Sep 2007
    I'd get the 3gb version too - it will future proof you quite a lot (and that is pretty much the only reason to get a 580 anyway!
  12. Guest-44432
    Guest-44432 Guest
    Same here. I might have to wait for the 3GB or 4GB GTX 680 when they come out. Cause at my resolution, Crysis needs allot of video memory!
    Cheers,
    Simon
