News Gigabyte has the POW-ERRR! Via USB.
Discussion in 'Article Discussion' started by Sifter3000, 28 Apr 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. Elledan
    Elledan What's a Dremel?
    4 Feb 2009
    It's nice to see USB catching up somewhat with Firewire in the available power department :)
    Still not sure about having USB as some kind of universal charging connector, though.
  3. wyx087
    15 Aug 2007
    how does the shut-off power thing work? would PSU be still turned on?
  4. capnPedro
    11 Apr 2007
    Dumb dumb dumb. They're messing with the specs and it's only going to end in tears. You know Chinese knockoff manufacturers won't implement things properly and stuff's going to get burnt out.
    The USB 3 spec should have just been designed with 2.5A as the maximum power it can supply. Then all these high draw appliances should either charge through a USB 3 port or flash a message saying it can't charge (i.e. for backwards compatability with USB 2) and have to be plugged in with a nice standardised barrel jack. We'd all upgrade to USB 3 sooner than the 2 bloody years it's going to take for rollout and everyone would be happy.
    Stupid manufacturers each with proprietary versions of "standard" connectors.. ****ing arseholes... I need to go for a walk.
  5. yuusou
    yuusou Multimodder
    5 Nov 2006
    Why do you keep
    scratching things out
    writing awesome articles?
  6. xalek
    xalek What's a Dremel?
    26 Jul 2007
    Errm... "With recent its motherboards" should read "With its recent motherboards"...
  7. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    With the boost in power that USB3 gives us, can we expect to see any 3.5" external drives that don't require a power brick any time soon? The current 2.5" USB powered ones are okay, but they just don't have the capacity I need.
  8. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    You don't have to be sure - the industry has already decided for you.
  9. Elledan
    4 Feb 2009
    I meant more from a practical standpoint. Look at the iPad requiring a non-standard 'USB' port for charging as an example. Devices like that depend on non-standard implementations of USB host ports. Combined with announcements like the one referred to in this topic, it makes me fear that USB may soon stop to be the 'universal serial bus' it once was.
    Of course, the iPad and such suck for not being able to trickle-charge from standard USB ports.
  10. GoodBytes
    20 Jan 2007
    Best article ever! :D
  11. nicae
    nicae What's a Dremel?
    25 Nov 2008
    I wonder if the power of greyskull on these USB ports is more likely to burn an improperly removed pendrive.
    As far as I'm concerned, more power to the people is never good. :p
  12. tad2008
    tad2008 What's a Dremel?
    6 Nov 2008
    All the time the PC is plugged in to the mains and has power going to it the PSU it technically always on. When you press the power button on your case this creates a connection on your motherboard that tells it to power up.
  13. wyx087
    15 Aug 2007
    cheers, lol.
    but im asking since if you have 2 USB3 devices connected each drawing 2.7A of power, that's way over the 5Vstb current spec on most power supplies. that means the PSU will has to be fully operational for 5v rail to be able to deliver power.
    i agree with most comments here, out of spec hardware should not exist. especially considering USB 2.0 shouldn't provide 500mA on plugging in, the hardware has to ask for it, otherwise it's only 150mA.
  14. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    that's just the standby voltage though.. would mean you can't use wake on usb devices
    edit- well actually you could.. the devices won't be pulling much of anything at idle
  15. PingCrosby
    PingCrosby What's a Dremel?
    16 Jan 2010
    Is the USB next door to the the USA?
  16. Azayles
    Azayles Minimodder
    6 Jan 2008
    Years ago I started a computer project which saw a mini-ITX board, screen, keyboard and trackpad mouse squeezed into an aluminium flight case. I designed the USB ports so that power was supplied directly from a separate PSU, therefore allowing several amps of current to power things like custom computer interfaces etc. I could also programatically switch off power to certain ports, as well as keep the power live when the rest of the computer was shut down.
    This idea from Gigabyte is pretty much the same (more power, and power present when machine switched off) so it's not really a new idea at all. I'm sure there's been countless people before me that've wired a higher current power source directly to their USB ports for charging and powering things.
    dark_avenger likes this.
  17. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    ^+1 rep for pro modding
  18. TWeaK
    TWeaK Minimodder
    28 Jan 2010
    More pics that can enlarge pleasethankyou!!
    Gigabyte are definitely my mobo manufacturer of choice atm.
  19. eternum
    eternum *blam* shotgun fanhole
    14 Oct 2007
    I lol'd - I shouldn't have, but I did!
  20. FreQ
    FreQ What's a Dremel?
    24 Jan 2009
    What 9000!?! :D
Tags: Add Tags
