News In Win to launch mirrored glass Tou case
Discussion in 'Article Discussion' started by Meanmotion, 4 Sep 2013.
  1. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
  2. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    I got a close look at this at i49 it is a stunning looking case but expensive for what it is. £600 afaik. To bad the rep was pushing the cheapo plastic cases rather than this to be honest.
  3. ev1lm1nd666
    ev1lm1nd666 What's a Dremel?
    23 Apr 2009
    I'd love to see a larger version of this with a stunningly simple/elegant water cooling loop installed
  4. Spraduke
    Spraduke Lurker
    23 Sep 2009
    Also saw this at i49 and definitely is the most interesting case I have seen in years (probably since the level 10). It had the "I want one" factor but also a complete finger print magnet. The touch controls on the front for lighting and fans where a nice touch to.
  5. Baz
    Baz I work for Corsair
    13 Jan 2005
    All these people at i49. We should have had a bit-tech meet-up.
  6. Meanmotion
    16 Nov 2003
    Next time will organise something. Was busy this year unfortunately.
  7. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    Cool concept, but I'm not that thrilled with the execution. The angular, bolted together parts at the front are a real turnoff for me, unfortunately. I think the glass treatment to something more understated like a Lian Li A75x / A76x would have come off better.
    Awesome concept for a modder though :dremel:
  8. Meanmotion
    16 Nov 2003
    I think you need the additional angles to create the right effect. Just flat vertical and horizontal panels would look too much like an actual mirror. I agree that the front is a little busy, though, with its handles and drive openings.
Tags: Add Tags
