Modding Painting Controllers?
Discussion in 'Modding' started by Darkwisdom, 4 Feb 2017.
  1. Darkwisdom
    Darkwisdom Level 99 Retro Nerd
    27 Aug 2011
    Basically I want to apply a bit of flair to a controller or two, and maybe a plastic case. Painting isn't the problem, but I want a super shiny clear coat that's suitable for handling. Does anybody know of what I would need for this. I have the skills, I just don't really know of the best brands and jargon when it comes to it.
  2. RedFlames
    23 Apr 2009
    Most of the how-tos i've seen have used something along the lines of this in terms of clear coat on the finished controller.
  3. Darkwisdom
    27 Aug 2011
    I was looking at that exact product, but I don't know what the finish is like. I assume it'd require curing for a few days.
  4. RedFlames
    23 Apr 2009
    Nicked from elsewhere but i think this is roughly how the end result turns out -
  5. Darkwisdom
    27 Aug 2011
    Ah, looks alright actually. I might get some and try with a crappy piece first.
  6. Spaceraver
    Spaceraver Ultralurker
    19 Jan 2006
    Remember to sand wet between coats to get rid of orange peel.. Polish to a shine after..
