Watercooling Coolermaster watercooling kits
Discussion in 'Hardware' started by jizwizard, 9 Mar 2012.
  1. jizwizard
    jizwizard Modder
    24 Dec 2010
  2. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    Looks like the perfect gateway drug to water cooling your PC.
  3. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    That does look like a good start, my concern is that pump. If it has that much power; Surely it'll cause issues with vibration? I'd rather not have a motherboard vibrating the whole time, simply because of the long-term issues that could cause.
    I do like the concept of having uniform sizing, though, so you can just haul the kit apart later when you decide you need GPU cooling, A res and the like. It's like a Customize your own H100.
  4. Concrete-Coffin
    Concrete-Coffin Minimodder
    5 Apr 2010
