LOW PPD on i7 2600K suddenly
Discussion in 'bit-tech Folding Team' started by Aegisx, 5 Jul 2011.
  1. Aegisx
    Aegisx What's a Dremel?
    8 May 2011
    Hi All,
    Second post in as many months, and still probably a newbie question :waah:
    I have an i7 2600K which was folding quite merrily. About 5 days ago it crashed and now I can only get about 2-3K PPD (it was at the 40K PPD). The current project is 6074, bigadv enabled (I know bonus has decreased), all cores used for folding.
    Is there a way to change project if that is what it is?
    Thanks in advance!
    Aegisx
  2. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    You can 'change' project by deleting the work folder. But I'd highly recommend you leave it to run its course and see what happens next time you get a workunit.
    Deleting work units to up your PPD isn't allowed by Stanford.
  3. One_Box
    One_Box Folder of the month April 2012
    11 Jul 2010
    I doubt it's the work unit, that is such a big reduction it seems unlikey.
    Processor speed ?
    Core voltage ?
    Motherboard ?
    All 8 threads @ 100% whilst folding ?
    Check your configuration file again, make sure you have -smp -bigadv -verbosity 9 set
  4. Aegisx
    8 May 2011
    Thanks for the replies!
    I can confirm:
    I am using FAH Tracker with the following options:
    "Use all CPU cores"
    "Enable -bigadv"
    Passkey set.
    Everything was ok. I was crunching a big WU (8995 points I think) and then FAH Tracker crashed. Since then I only have small units. :(
  5. RedFlames
    23 Apr 2009
    IIRC 6074 is a regular SMP unit, not a bigadv unit
  6. Aegisx
    8 May 2011
    ok, that would make sense on the PPD. Is there a way to force bigadv units? I definately have bigadv set, in my log file:
    Arguments: -oneunit -forceasm -smp -bigadv
  7. noizdaemon666
    15 Jun 2010
    Not until you've finished the work unit you're already on. And then you should get a bigadv work unit if there are any available.
    Any reason you're using the oneunit flag?
  8. Aegisx
    8 May 2011
    no, not sure what it is or where it is set within FAH Tracker. I suppose the next question is whether I shoudl just go back to the command line and run the SMP client there rather than in FAH Tracker (presuming of course FAH Tracker is the source of my issue)
  9. noizdaemon666
    15 Jun 2010
    The oneunit flag lets f@h get a unit, finish it, upload it then pauses. So it won't download another work unit. Or that is as far as my understanding of it goes.
    And it might be worth a shot just using the command line version. Unless someone can think of a reason not to that is.
  10. Leroyingo
    Leroyingo What's a Dremel?
    2 May 2011
    To take out oneunit in the Tracker - settings - configure - then tracker settings tab - under client settings on that page is one unit tab, then you can select any clients for one unit, take out the tick in the smp box to remove one unit.
  11. Chicken76
    Chicken76 Minimodder
    10 Nov 2009
    Any i7, let alone a 2600K, would produce a five-figure ppd just crunching regular SMP workunits.
    2-3K ppd is the production of a dualcore.
  12. One_Box
    11 Jul 2010
    A 2600K @ 4.5Ghz running SMP (Windows) will yield approx. 25K PPD.
    Personally I don't use 3rd party applications to run my folding clients so am unable to comment on FAH Tracker. I would however try running the SMP client natively and see what happens.
  13. Tattysnuc
    Tattysnuc Thinking about which mod to do 1st.
    19 Jul 2009
    Make sure the file client.cfg contains the CORRECT passkey. I mistyped mine a little while back and couldn't work out why I waspicking up std work units.
    Also, low ppd might be due to the ETA of the work unit being passed the deadline. When was the unit downloaded? What is your time per fold?
  14. Aegisx
    8 May 2011
    Thanks All. I will ensure the passkey is set correctly and probably move to the client rather than the Tracker... will update in a couple of days...
  15. Aegisx
    8 May 2011
    Hi All, I have just had a thought (scary).
    I have now started using the SMP Client instead of FAH Tracker. Passkey entered correctly. However it is still processing small units (if thats the correct phrase). Current Project is 6051. This is 500000 steps, and I used to get 10000000 step projects.
    Could it be either:
    A. I am just unlucky to be getting small units?
    B. Can a client be 'penalised' for bad practice? My machine had failed on units with 'UNSTABLE_HARDWARE'. Is it possible that as a result units may be handed out cautiously until the hardware proves itself again?
  16. Leroyingo
    2 May 2011
    You need to return 80% of units successfully to get bonus points. Maybe if you don't fill these requirements then it wont issue you with -bigadvs
