Case Mod - In Progress BF4 Radio Beacon Casemod by Ironknocker
Discussion in 'Project Logs' started by Ironknocker, 25 Apr 2016.
  1. Ironknocker
    Ironknocker Minimodder
    4 May 2014
    Hello,
    Then I start my Worklog.
    I build this Casi at the We-Mod-it.com Casemod Contest.
    My goal is to build dustproof possible workshop computer
    The Case I'll rebuilding so that it looks like the Raidio Beacon of BF 4
    What is being done:
    designed front new
    Window cut
    build Conditions
    Hardtubing
    seal housing
    lighting
    switch
    Material is :
    aluminum Plexi
    This is the template :
    This are the first draws of the mod
    That's it for the moment
  2. Ironknocker
    4 May 2014
    I then plays after a long back another round and used to make a few images from the game.
    Then I searched and found the original in the internet.
    When housing and the front some things are compared from the game to the original differently.
    I Buld it from the Game.
    Then I once slaughtered my garage computer and expanded the hardware.
    The motherboard I will install in the Beacon.
    Next, I once searched my treasure box by material and what is found.
    That's a old console I purchased cheaply at the Ham Radio.
    The small WLAN Antenna I will replace it with a blade antenna.
    The I then found today in the bay.
    Then I have bought various connectors.
    One part comes from China the rest of Conrad.
    Guess that should come quite quickly, otherwise more will be ordered at Conrad.
  3. storm-83
    storm-83 Minimodder
    7 Nov 2014
    * grabs popcorn and pulls up a chair *
    consider me subbed!
  4. Ironknocker
    4 May 2014
    Update Time.
    So packets have come
    First the case.
    Then the antenna and connector has arrived yet.
    Same time to unpack the case.
    Since I'll probably have to change more than planned. Since the welder is glowing.
    The antenna is super.
    When Conrad packet NEN Fail was there.
    Once a plug and a socket.
    Only stupid that was labeled or packaged a false.
    After I then measured the Case I realized that will not fit with 2x80 radiator.
    So the case must 10 mm raised.
    For this, I will cut the cover and (front and back Old) to the side parts and weld it together.
    Then I'll make a front and bottom.
    The new front I drew ever with CAD.
    That's t for today
  5. Ironknocker
    4 May 2014
    update:
    I have drawn even further.
    First all components radiator reservoir and pump
    Radiator will be a 2x 80
    The reserve tank I finished from 30 square tube The Hatched is the area where later the water is inside. The rest of the expansion tank frame is made of a halved 30 square tube.
    So the system looks ready later.
    From Front
    And from above
    Today, more packets are yet come.
    A large packet of Aquatuning and one from Conrad.
    One can hardly believe it. Conrad has again delivered wrong. So again complained about. :wallbash:
    Now the packet from Aquatuning.
    Thanks to these sites on [url = 'www.aquatuning.de'] Aquatuning [/ url] for their support in this project.
    Two heatsink
    A radiator and fan (sweet little)
    Plenty of fittings
    Pump with extension
    Hardtubes
    and temperature displays
    Then it was still in the basement
    First I cut the lid.
    Then I have the front shortened and welded part of the lid
    The same, I then made with the back
    Now I could be all just sand.
    In the next step I have the parts new thread cut and bolted to the bottom plate.
    From a scrap piece I then cut the new base plate.
    Finally, I still set the new location from the motherboard and power supply.
    The cables later gone down. At the plug I come later through the IO port of the old rear.
    That's it for today
  6. Ironknocker
    4 May 2014
  7. abbas-it
    abbas-it We came, we saw, we mod, you awe!
    1 Jun 2011
    hey bud, thats some serious metal work you got going there, looks great so far..
  8. Cheapskate
    13 May 2007
    That was a really good weld job. What are you using for that?
  9. Ironknocker
    4 May 2014
    the mod will be my worstation at the Workshop.
    I welded it with Tig / Wig
  10. Gazmtk
    Gazmtk What's a Dremel?
    3 Dec 2014
    Welding a PC case = Overkill = Loving it!!
  11. abbas-it
    1 Jun 2011
    yes guys and this is all hand icrafted no cnc and co....:rock:
  12. Ironknocker
    4 May 2014
    thanks, people.
    Ya Ali I have to agree with you.
    How good a modder is can be recognized by his handiwork.
    The day I started with the front panel.
    For this purpose I have printed the drawing and glued to a piece of sheet metal.
    Then I could work out with the start of the openings
    After all holes were finished, I folded back the sheet with the folding machine.
    Fitting perfect.
    That's it for today
  13. Arboreal
    21 Jan 2011
    Very nice handiwork, that'll do for the day! Now have a well earned beer
  14. Ironknocker
    4 May 2014
  15. Ironknocker
    4 May 2014
    So on it goes to the front.
    First I printed the front glued to a sheet and then oriented.
    From the rotary switch I need only one switch plane, as I have cut off the other, thus shortening the switch.
    Then I could install switch and lamp.
    Next is a plug (the rest comes hopefully) and the antenna.
    The panel I have also made aluminum.
    In addition I have a folded sheet cut and welded.
    This is the position where the display sitting Later under the panel
    Finally, I then bolted the panel on the front panel.
  16. Ironknocker
    4 May 2014
    update Time
    Today we went to the reservoir.
    The will be the supporting part in the case.
    The container is made of 25mm aluminum tube.
    The tube I cut with the band saw.
    In the second step I have stretched the tubes on a board and welded.
    Then grind everything
    On one side I have a lid welded to determine the load capacity.
    115ml fit inside.
    Next came the strikes 1. Connection and the second cap.
    Everything tight.
  17. Ironknocker
    4 May 2014
    It continued with the expansion tank
    First I cut pipes for the other two sides.
    he tubes I then halved.
    Then all welding and grinding.
    Now I was able to put under the case.
    Today is still material come.
    First the paint.
    2K Nato Oliv dull matt. Woe is not dull matt
    Then RPS cups are yet come for my Sata gun.
    And finally, Conrad has actually hammer out after 3 incorrect deliveries to send me the correct plug.
    Then I quickly folded the box for the battery dummy or housing for the pump and Radi.
    In addition I have first to cut a sheet.
    and Bend
    The corners, I have to make fast times with tape fixation to a fitting.
    Proportions fit well. The corners are then welded at the weekend.
  18. Cleveland216
    Cleveland216 Carbon Fiber King
    30 Dec 2007
    Nice build log and it was just getting interesting!!
  19. Ironknocker
    4 May 2014
    Update
    Today a packet has arrived again.
    Tanks to Enermax for the support at this project.
    Here's the overview.
    A BT speaker is designed for Case Fits. The speaker is then controlled via the computer internal BT transmitter.
    Fans
    Headset Mount
    and an external HDD case
    Further, it was of course also in the workshop.
    Today I have the corners of the box welded
    After that was done could the welds are ground.
    Then the amount had to be adjusted so that the body-surface rests on the expansion tank.
    Again do everything together.
    Next, I started expanding the expansion tank to transferor part.
    First, customize a few angles from a scrap piece tube.
    This I then welded to the tank ..
    Now I was able to adjust the Case and the screwing.
    The radio will later slightly inclined on the table and have eyes, so I can hang it in the workshop at the ****.
    First I again halved a piece of the pipe. Am I a happiness that the pipe has the same wall thickness as the thickness of the MB tray.
    Then drill a few holes.
    Next, I cut the cutouts with the scroll saw.
    Now everything could be worked with a file.
    For wall mounting I just turn a pair of rakes in the wall and hanging the in the slots
    Before welding a taste .
    then the end I was able to unpack the welder and weld everything.
  20. Ironknocker
    4 May 2014
    In the reservoir, I have welded a strut.
    clean This wears out the battery box and walk through the narrow remaining opening later the cables from the IO panel.
    Then everything again screwed together and check.
    In the next step I then installed plug into the front.
    It continued with the cooler tag.
    For that I first cut a piece of copper.
    The holes I transferred with masking tape from the old radiator.
    still cutting threads and screw it to the motherboard.
    That was it again for the moment.
