Watercooling Ok so I won't be fitting my 680 waterblock.
Discussion in 'Hardware' started by feathers, 12 Apr 2012.
  1. feathers
    feathers Minimodder
    11 Apr 2009
    Because no one told me they changed from using screws to Torx!
    I took the GPU out and then removed one of the regular screws around the core, then tried one of the smaller screws around the edge, only to find it's something called Torx. I did a search online and there is a reference someone made about it being Torx T6 on Nvidia 680. I have Zotac 680 so I guess they're using these now instead of regular screws.
    So I won't be fitting the block until I get the damned T6.
    It is a T6 isn't it?
  2. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    T6 is absolutely tiny - my torx bits only go down to T10
    I think T6 is the same sort of size as that used in mobile phone - hp server screws that are Torx generally are T10's
  3. feathers
    feathers Minimodder
    11 Apr 2009
    I got a crappy cheap toolbox with various odd shaped tool bits. Torx is there but no T6 that I can see. I should throw that box away because whenever I have encountered an odd screw shape, that box has never had the correct shape or size.
    It has more than 40 pieces.
  4. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
  5. feathers
    feathers Minimodder
    11 Apr 2009
  6. dead beat
    dead beat Rippin six 4 life
    15 Feb 2009
    Haven't they always been T6's? They certainly were on the 580.
  7. megadriveguy
    megadriveguy Minimodder
    19 May 2010
  8. feathers
    feathers Minimodder
    11 Apr 2009
    Regular screws on the 560ti's and all the previous GPU's I had.
  9. feathers
    feathers Minimodder
    11 Apr 2009
  10. N17 dizzi
    N17 dizzi Multimodder
    23 Mar 2011
    my 580 is almost entirely t6's... local hardware shop had the right size for £2
  11. feathers
    feathers Minimodder
    11 Apr 2009
    Can't be assed to leave the house until saturday.
  12. N17 dizzi
    23 Mar 2011
    Send me your card, ill unscrew it for you. And send it back even better and longer with a different bios
    :naughty:
  13. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    Good job I saw this thread as I normally rush in to thing's and find I need something and then have to start, either trying to find somewhere who sells them or bodge something together to do the job with these card's though I will probably take mine to Scan as they said they will fit, the block for me as I really don't want to fry the card (chicken).
  14. dead beat
    15 Feb 2009
    You have a modified 680 bios?
  15. feathers
    feathers Minimodder
    11 Apr 2009
    He writes his own bios.
    He doesn't rely on Nvidia bios.
    He uses his own drivers too.
  16. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    I thought all high end Nvidia cards since at least the gtx 480 have had t6 torx screws on them? My EVGA gtx 580's did and the one that I got from deadbeat also has them. Only 580's I knew of that had normal screws where EVGA 580's with IHS, but not many of them did have those.
  17. feathers
    feathers Minimodder
    11 Apr 2009
    I've never had a high end GPU b4...
  18. thetrashcanman
    18 Nov 2010
    Ah har, well welcome to the club feathers :)
  19. feathers
    feathers Minimodder
    11 Apr 2009
    I have a vague memory of once paying £240+ for an FX 5900 ultra.
    It turned out to be Nvidia's worst GPU.
    I can't even remember buying it or how I came to pay £240+ for it.
  20. N17 dizzi
    23 Mar 2011
    Bob and Cyril
