Graphics SLI GTX 570 vs. GTX 670/Radeon 7970
Discussion in 'Hardware' started by TheBlackSunshine, 29 Apr 2013.
  1. TheBlackSunshine
    TheBlackSunshine What's a Dremel?
    6 Sep 2011
    Did a quick search and the general consensus is go for a single GPU, but...
    I can pick up 2 GTX 570s from a friend for £250. A new GTX 670 or Radeon 7970 would set me back about £300 - £350. Is it still preferential to go for the single GPU option?
    Thanks
    EDIT: Btw I am currently using a GTX 560 Ti.
  2. Neogumbercules
    Neogumbercules What's a Dremel?
    14 Aug 2004
    What games/res are you playing? A single 670 can pretty much max out most games and it's a lot less hassle. I think the dual 570s would outperform though. If you can max out with a single card I'd say go with that. SLI means heat, noise and excessive power draw.
    Sent from Bittech Android app
  3. docodine
    docodine killed a guy once
    10 Feb 2007
    the 570s will be faster assuming the game you play has good SLI scaling
    the sli 570s will draw nearly 2x the power of a single 7970 though, and they'll run pretty warm because they're fermi...
    i'd take a new 7970 out of your options
  4. Instagib
    Instagib Minimodder
    12 Mar 2010
    The 570's would have a shorter lifespan with the 1.3gb of vram on them compared to the 2 or 3gbs on the newer cards.
    For now though, the 570's are very capable.
  5. Shirty
    18 Apr 1982
    If you bought a 7970 and overclocked it you would essentially match the performance of SLI 570s for a lot less heat, power and noise.
    I also think £250 is a bit excessive for a pair of 570s unless they come with waterblocks. £200 collected or £210 delivered is as high as you should be willing to go.
  6. mrbungle
    20 Sep 2004
    Pick up a 670 or 7970 for around £300. Forget the sli.
  7. Tangster
    23 May 2009
    Heck, even less sometimes. My 670SC 4GB cost me £225.
  8. jinq-sea
    15 Oct 2012
    I'd probably have a look for a reasonably priced 7970 (or if that's a bit steep at the moment, a 7950). Heck, you can always chuck another one in later!
  9. Shirty
    18 Apr 1982
    7950 for £170 to £185, preferably one that's known to overclock like a monster, and you have 680 performance (or better if you're really lucky) for half the cost.
  10. jinq-sea
    15 Oct 2012
    My ref. Sapphire 7950 clocks like a b*tch, and now retails around the £200 mark IIRC.
    Yes, fewer shaders than a 7970, but fast clocks = cheesecake.
  11. TheBlackSunshine
    6 Sep 2011
    Right guys thanks for the advice. I think the consensus is pretty clear: Go for the single GPU solution. In which case I can wait to see what Computex brings...
    Thanks again!
