Hey all, Failing to find anyone selling RAM in the for sale threads so .. what's the cheapest (but reliable) RAM that you can put in a socket 1155 motherboard (The Asus P8Z68-v Pro/Gen3 if it matters) Would be looking for 8,16, or 32GB sets. thanks in advance!
Here's the cheapest stuff I would put in a PC: 8GB 1333MHz 8GB 1600MHz 16GB 1333MHz 16GB 1600MHz 32GB 1600MHz
Thanks The 32GB set is sooo expensive :/ Any reason you'd not use cheaper? (I've got no intention of OCing it or anything)
I've used Corsair before so I know they're reliable and they have a lifetime warranty. OcUK have a broader range of manufacturers so i've had a look there too: 8GB 1600MHz 1/2/3/4/5 (all £53.99) 16GB 1600MHz 1/2 (both £107.99) 32GB 1600MHz Those are the cheapest ones I can find and they are a bit cheaper than Scan. It also looks like most, if not all of the OcUK ones offer a lifetime warranty too. To be honest, I think as long as it's branded, it should be fine.
Mkay! Noted - was going to maybe look at the value stuff (no cool heat spreaders etc) - was just worried it would be sucky.
