Hardware The big air cooling investigation
Discussion in 'Article Discussion' started by brumgrunt, 10 Feb 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. jakobfrimmel
    jakobfrimmel What's a Dremel?
    2 Jan 2011
    Interesting read!! bout time someone did a serious investigation into this!! next we want a water-cooling version.....
    oh and first comment :)
  3. David
    7 Apr 2009
    Nice article. Something to provoke a little thought - a traditional bit-tech piece. :thumb:
    Teelzebub likes this.
  4. weesteev
    weesteev What's a Dremel?
    19 Dec 2011
    Great article guys, back to the good old days of bit-tech IMHO. Keep up the good work.
  5. tonyd223
    tonyd223 king of nothing
    12 Nov 2009
    Brilliant - and about time - good work.
  6. GeorgeK
    18 Sep 2010
    Excellent article - I'll be altering my setup as a direct result of this - cheers!
  7. Shichibukai
    Shichibukai Resident Nitpicker
    29 Sep 2009
    +1
  8. RobJapan
    RobJapan What's a Dremel?
    29 Mar 2011
    I currently have two fans in the roof of my case, I'm going to take the roof front fan out as you suggested and see what the results are!
    great article!!
  9. sandys
    sandys Multimodder
    26 Mar 2006
    You should have taken sound levels as adding more fans doesn't increase noise as much as some might think.
  10. cjb119
    cjb119 What's a Dremel?
    1 Sep 2009
    agree, a single noise measurement per number of fans would have been nice.
    now I've just got to work out what my roof fan is doing? exhaust or intake:)
  11. LJF
    LJF Modded
    6 Jan 2010
    Have I slipped back in time some how? this is the kind of article that first attracted me to Bit-tech! Good stuff.
  12. blackerthanblack
    blackerthanblack Minimodder
    17 Sep 2004
    Agreed. I was sceptical of the new set up for this year, although I have been less and less enthusiastic about the more recent BT set up over the past year or so. The new articles seem to be getting back to the BT roots and what first got me coming back to this site - nice.
  13. Jqim
    Jqim What's a Dremel?
    10 Jan 2011
    I like this becuase It made me rethink ideas i had concreted in my head. Like "front to back cooling wins always". I do plan on buying a fractal r3 at some point and i tihnk i will have 3 fans in it, I may leave it as 2 at the front and 1 rear even though i know it is wrong. The reason for this is dust a few degrees of heat i can handel but dust drives me insane.
  14. do_it_anyway
    do_it_anyway Minimodder
    24 Apr 2009
    Fantastic, in depth article. Well done.
    My only problem is that on my Antec 902 with a titan fenrir cooler, fitting a side fan causes it to hit the CPU cooler. So in order to make the side fan work, you either need a cavernous case, or a slightly shorter CPU cooler. Unless anyone knows of any low profile fans..?........
  15. Siwini
    Siwini What is 4+no.5?
    14 Sep 2010
    About time someone went to work. Gob well done.
  16. longweight
    7 May 2011
    I recently fitted a fan controller to my FT02 and I have been amazed at how quiet it now runs (fans on minimum all the time). This hasn't affected temperatures either! The only fan I can hear now is my GPU!
  17. JCBeastie
    JCBeastie What's a Dremel?
    10 Nov 2005
    Excellent article, best thing I've read in a long time (takes me back to reading magazines! who remembers those :p).
    Slightly annoyed at the efficacy of a side fan; I hate those.
  18. Tattysnuc
    Tattysnuc Thinking about which mod to do 1st.
    19 Jul 2009
    Wonderful to see a good old fashioned analysis - EXCELLENT work guys.
    My only gripe, and it's a VERY minor one, is that it would be nice if above each review you did a diagram to show the positions of each of the fans...
    +1 to the watercooling being the next one.
    Welcome back. I'm so pleased to be back on the good ship Bit-tech.....
  19. S1W1
    S1W1 Minimodder
    25 Mar 2011
    I have been waiting for this for so long :D Very nice article BT
    Now all you need is a 120mm/140mm fan round-up, to determine the best 120mm/140mm fan. It's so hard to choose between different fans- a fact which isn't helped by completely inconsistent manufacturer figures.
  20. Tyrmot
    Tyrmot Minimodder
    12 Mar 2008
    Indeed! Exactly what I own... and all housed in an R3 as well. Great article thanks!
Tags: Add Tags
