Other Anyone had any issues with Samsung kies?
Discussion in 'Software' started by CrapBag, 15 Mar 2013.
  1. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    I have been trying to get my Samsung Galaxy S 5.0 to connect to Samsung Kies so I can see if it's running the latest OS and possible update it (not sure if I want to risk updating it mind you, dont want to brick it) but it refuses to connect.
    I have tried lots of possible fixes but nothing has worked, anyone had any experience on this?
  2. RedFlames
    23 Apr 2009
    Trying to get my galaxy ace to connect is always a hit and miss affair
  3. Booga
    Booga Cuppa tea anyone?
    28 Sep 2009
    Yes I have had the same connection issues, it is just a rubbish piece of software. I uninstalled and reinstalled but it is still picky about when it decides to connect to your phone.
    I usually just keep disconnecting it the reconnecting it.
    I have updated my S3 via Kies (when it did connect) and no issues.
    However every time I start up I get a message the Kies has downloaded the latest update, despite the fact that it was already downloaded and installed.
    For phone to PC connection (excluding updates) Airdroid is way better imo.
  4. Yslen
    Yslen Lord of the Twenty-Seventh Circle
    3 Mar 2010
    Had this issue with a Galaxy SII and it turned out it needed the original USB cable to work at all. No idea why that was the case, but it's worth mentioning I guess.
  5. GeorgeK
    18 Sep 2010
    I've had about a 5% success rate with making Kies work with my phone and a 0% success rate with my tablet... Worst piece of junk I have the misfortune of having installed on my computer imo...
  6. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Think it's going to get uninstalled to be honest, I was a bit nervous of updating the firmware as it was but if the software is that flakey I don't think I can trust it even if it did manage to connect.
    Thanks for the idea Yslen but it was the cable that came in the box so I think I can rule that out.
  7. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    Update via the phone itself rather than pc update.
    Settings>About>Update.
    Use wifi and all downloads and installs fine.
    I did the latest update last week.
  8. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Unfortunately there isn't an update option in the about section.
  9. Xir
    Xir Modder
    26 Apr 2006
    It's an S, right?
    I've got an S+, and it doesn't seem Samsung is offering any upgrades.
  10. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    That's probably the case but I read somehwere you can use 2.3.3 but I'm probably wrong, my daughter seems happy with it as it is. I was only going to try to get it updated as she can't use team speak with the OS version she has.
  11. aramil
    aramil One does not simply upgrade Forums
    10 Jul 2012
    Have a look on xda forums for your model. Got to general section and select stock roms.
    They will advise you to use "odin" to flash
    (All instructions and downloads are there)
    Dont use kies. It hardly ever works correctly.
    Have been doing this for years with my Samsung S2. On JellyBean 4.1.2 atm.
  12. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Can only find posts referring to the stock rom, I don't know what version is possible, new to this and somewhat lost.
    This is what we have
  13. sniperdude
    sniperdude Minimodder
    8 Sep 2010
    tried USB debugging mode?
  14. aramil
    10 Jul 2012
    If you go to system setting-about device and quote the model number listed there (not all similar devices have the same number. ...)
    I will see what there is :thumbup:
  15. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    YP-G70CW
  16. aramil
    10 Jul 2012
  17. wolfticket
    19 Apr 2008
    Endless connection issues with my Galaxy S3. Complete pain in the ass.
    Ended up using Airdroid instead for file transfers and such.
    Luckily for me the last time I managed to get Kies to connect to check for updates the update seemed to add over the air updates to Android, which mean Kies never need darken my door again.
    As for getting Kies working.
    Well:
    • Uninstall everything Kies related (inc drivers).
    • Restart the computer.
    • Download the latest version of Kies.
    • Disconnect your computer from the internet (can help as it should disable Windows automatically looking for alternate drivers on the web).
    • Install Kies following the instructions for when to connect religiously.
    • Hope for the best that it might connect once so you can update.
    • Mess around with USB debugging because that might help.
    • Find that doesn't help.
    • Repeat all of the above thinking it might help.
    • Waste time trying various other things.
    • :wallbash:
    • Give up.
  18. sniperdude
    8 Sep 2010
    Can't say I have ever had an issue with it myself.
  19. Xir
    Xir Modder
    26 Apr 2006
  20. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Thats odd, it's got an S on the back.
