Case Mod - In Progress Silverstone TemJin TJ11 Mod
Discussion in 'Project Logs' started by Marscorpion, 9 Nov 2014.
  1. Marscorpion
    Marscorpion What's a Dremel?
    6 Nov 2014
    Hi,
    I'm new to this forum and now it's time to start my first worklog, "Silverstone TJ11 Mod" :rock:
    This is my old build with xigmatek elysium:
    Hardware to be used:
    • Silverstone Temjin TJ11
    • Intel Core i7 5930K
    • Asus Rampage V Extreme LGA 2011-v3
    • 2 X EVGA GTX 980 SC
    • Corsair AX1200i
    • SSD Samsung 850 PRO 256 GB
    • WD Black 750 GB 2.5"
    • DDR4 G.Skill Ripjaws 2666 Mhz 16 GB
    • Asus ROG SWIFT PG278Q
    Liquid cooling:
    • EK-Supremacy EVO - Nickel
    • 2 X EK-FC980 GTX - Nickel
    • EK-FB KIT ASUS R5E - Nickel
    • 2 X EK-RAM Monarch X4 Clean CSQ + EK-RAM Monarch Module - Black
    • 2 X Alphacool VPP655 - single edition
    • Bitspower D5 MOD TOP - Clear "S"
    • 2 X Bitspower Dual / Single D5 Top Upgrade Kit 150- Clear
    • 2 X Bitspower D5 Mod Kit Matt Black
    • Raccordi Bitspower Silver Shiny
    • Acrylic tube 12/10mm Clear
    • XSPC Quad Fan Radiator AX480 black
    • 2 X XSPC Triple Fan Radiator AX360 black
    • XSPC Dual Fan Radiator AX240 black
    • Aquacomputer aquaero 6 XT USB fan controller
    • Aquacomputer Flow sensor 'high flow' G1/4
    • Aquacomputer flow rate sensor mps flow 400
    • 12 X Cooler Master 120mm JetFlo FAN - non-LED
    • 3 X Cooler Master 120mm JetFlo FAN Red Led
    Sponsor : My wallet :D
  2. GeorgeK
    18 Sep 2010
    Moved to modding until there are pictures of work in progress.
  3. Marscorpion
    6 Nov 2014
    First items arrived:
  4. Marscorpion
    6 Nov 2014
    Ready for mod ........
  5. Marscorpion
    6 Nov 2014
    First stage - front panel mod ! :rock:
  6. Marscorpion
    6 Nov 2014
    Aquaero 6 XT is arrived.......
  7. Marscorpion
    6 Nov 2014
    Work in progress..... :dremel:
  8. Marscorpion
    6 Nov 2014
    Small update.....
  9. GeorgeK
    18 Sep 2010
    Moved back to Project Logs - good luck with the rest of your build!
    GK
  10. Marscorpion
    6 Nov 2014
    many thanks ;)
  11. Marscorpion
    6 Nov 2014
    Some of the work on lateral cover is finished.... :dremel:
  12. Marscorpion
    6 Nov 2014
    .... and the second lateral cover ...... :)
  13. Marscorpion
    6 Nov 2014
  14. Marscorpion
    6 Nov 2014
    Small mod on the original midplate....
  15. Marscorpion
    6 Nov 2014
    New arrivals:
    ..... and case mod update:
  16. Marscorpion
    6 Nov 2014
    Bitspower items:
    Upgrade case mod ...
    Work on acrylic panel with milling machine:
  17. lowfat
    lowfat Minimodder
    4 Jul 2013
    I really like your sleeving choices and the coolant from your last build. Curious to see what you do w/ this rig.
  18. Marscorpion
    6 Nov 2014
    Soon I begin to make cables and sleeving :thumb:
  19. Marscorpion
    6 Nov 2014
    Some fans :D
    Work in progress on midplate for radiator and through holes:
  20. Marscorpion
    6 Nov 2014
    This is original side panel. I don't like two small rectangular windows.
    And that's my remedy for this:
    This is the final result:
