SketchUp Project :: [GT] Carbide Series - Acrylic Full Tower case , by iD2
Discussion in 'Modding' started by iD2, 17 Jun 2013.
  1. iD2
    iD2 Minimodder
    25 Mar 2012
    Welcome!​
    Project Name :: [GT] Carbide Series
    Project Concept :: It not just system , it your STYLE
    Project By :: iD2
    [​IMG] [​IMG] [​IMG]
    6 Colors to compatible with your component
    2 version release , Right hand style and Left hand style
    Specification ::
    Model :: [GT] Carbide Series
    Dimension :: 620mm x 540mm x 260mm (W x H x D)
    Material :: Acrylic
    Color :: 6 colors
    Side Panel :: Transparent Side Panel
    DVD 5.25″ bay :: 1
    HDD 3.5″ bay :: 2
    HDD 2.5″ bay :: 7 (3x for Show your SSD or HDD , 4x for standard use)
    Motherboard :: ATX or mATX
    Case Type :: Full Tower chassis
    System Fan (Font) :: N/A
    System Fan (Rear) :: 1x 120mm
    System Fan (Top) :: 4x 120mm
    System Fan (HDD) :: 2x 120mm
    System Fan (Rear buttom) :: 2x 120mm
    Features ::
    - 2 version release , Right hand style and Left hand style
    - Support 4x120 radiator
    - Transparent side panel (show your style here)
    - Support 6 colors to compatible to components inside
    - Support custom name on font ( see it at "[GT] Carbide Series")
    I would like to share my project i have been design for a couple month.
    This design still not 100% complete and i think i'll go to start my project next week but i need to sell my CNC machine for some reason so i'm not sure this project will start or not , however i need to share my design need to see what you think.
    Hope you like it.
    PS. I'm not good in English , If i make you confuse please feel free to ask me.
  2. iD2
    iD2 Minimodder
    25 Mar 2012
  3. iD2
    iD2 Minimodder
    25 Mar 2012
    reserve :D
  4. iD2
    iD2 Minimodder
    25 Mar 2012
    Now my old CNC already sold that make this project freeze , So i start to design my low cost CNC to support to cutting acrylic , wood and/or aluminum (for aluminum will not over than 3mm).
    Just finish design Z-Axis
  5. Cheapskate
    13 May 2007
    Sweet!:D
    I like the modular white panels on the motherboard tray in particular. You might want to line the SSDs up with the three under the motherboard. The discrepancy makes my OCD itch.
    Anyway, I'd go nuts with the white on black. -Maybe make some covers for the front edge of the top fans.
  6. iD2
    iD2 Minimodder
    25 Mar 2012
    Thank you, i"ll consider about that. For this design still have some issued but i'll solve it after my new CNC design was finish. So for this project i'll open 2 work log ,
    1st - to Build CNC machine
    2nd - to Build this Acrylic case
    :D
  7. iD2
    iD2 Minimodder
    25 Mar 2012
    Not finish yet , but this my 1 of 3 type of my design for X-Axis. The other type will use less aluminum profile and not use linear guide way to reduce cost.
    After finish all design i'll open new work log for
  8. iD2
    iD2 Minimodder
    25 Mar 2012
    Still working on it , it not finish yet.
  9. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    Mind if I ask where exactly air enters the case? I don't see any intake fans/ intake vents, but I do see an air-hungry beast of a 480 radiator. Or are you intentionally hiding the intakes?
    Other than that, Really nice job! Especially like the differently-colored Graphic's logos. :thumb:
  10. iD2
    iD2 Minimodder
    25 Mar 2012
    The air enters from bottom right side and top right side by using 120mm fan (4x120mm fans).
    For this side i'm not show my design yet because i'm still working on it and try to make it fit to my design but now my design still freeze, i'm working on my CNC design first.
  11. RebootTech
    RebootTech Budget? What Budget?
    11 Jul 2012
    Love the wrap around acrylic...awesome that you can see in the case from the front and side seamlessly. Great design work!
  12. iD2
    iD2 Minimodder
    25 Mar 2012
    Thank you. :D
  13. iD2
    iD2 Minimodder
    25 Mar 2012
    Redesign my CNC to replacement X, Y Axis linear guide by rod rail but jut finish only Y-Axis (Some design call X-Axis)
  14. skyrip
    skyrip What's a Dremel?
    22 Jun 2013
    seems kind of wasting money to use high price lineair guides on the y an z axis and use cheap ones on the x axis.
    also maybe it is better if you change the design a little bit and remove the weak vertical posts and just build the lower frame like a U
    not saying mine is perfect but it is pretty dawm strong
    that is how i build mine, this has also been done with aluminium profiles.
  15. iD2
    iD2 Minimodder
    25 Mar 2012
    Thank you for information, For my design above i'll replace X, Y to use rod rail to make it cheap and for Z-Axis i'm still use linear guide because it have a lot second hand part and it cheap (about 40$ for 2xrail , 4x block).
    Now i have 6 different design and some design remove the weak vertical posts too but it not fit to my condition.
    My condition ::
    - Build this CNC by using 1 power drill
    - Build this CNC by using only hand tap tool
    This all tool i only have.
  16. skyrip
    22 Jun 2013
    i made this one with only a hand tap(machine version but did it with manual labour)
    parts i designed and had them made at a shop with a water jet and bending tools.
  17. skyrip
    22 Jun 2013
    maybe it would be wise to post your cnc ideas on a cnc specialized forum like cnczone.com. those people wil definately be able to advise you about the best choise.
    there are enough companies that can cut steel or thick aluminium sheets, so its not so hard to build one.
  18. iD2
    iD2 Minimodder
    25 Mar 2012
    My revise design , replace linear guide by rod rail but replace only X and Y Axis because linear guide for Z Axis have a lot used part and it cheap.
  19. skyrip
    22 Jun 2013
    i would not reccomend the little L parts connecting your bridge to the x-axis. a better idea would be to buy for the side bars a 120x80 bar and mount the bridge directly onto the x-guides. this design is probably even weaker than the first. guides on the top is better.
  20. iD2
    iD2 Minimodder
    25 Mar 2012
    Thank you for your recommend and sorry for reply late just busy to finish my design and now i start order parts for it.
    For L parts i use aluminum sheet to connecting it and will use angel bracket too. I'll update my final design again and now some parts it arrive.
