News Latest WGA deletes wallpaper
Discussion in 'Article Discussion' started by Guest-16, 28 Aug 2008.
  1. Guest-16
    Guest-16 Guest
  2. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    As if any pirate will care about backgrounds and 'text" appearing in some corner. they know they have a copy.
    As if any legit user will care about the "your windows is genuine" msg when doing a ms driver upgrade.
    As if anybody cares if you have a honest or pirated windows.
  3. badders
    badders Neuken in de Keuken
    4 Dec 2007
    It's true though - it seems to be all stick and no carrot when it comes to getting people to shell out a fortune for an OS...
  4. Glider
    Glider /dev/null
    2 Aug 2005
    A fortune is relative... People don't bother dishing out €350 for JUST a GFX card, but when it comes to one of the key components, the OS, then every € is one too much...
  5. Silver51
    Silver51 I cast flare!
    24 Jul 2006
    £60 OEM.
    I'd rather build my system with a trustworthy OS version rather than struggle with a dodgy pirate version.
  6. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    that's just plain irritating! hehe! have M$ dropped the price of XP with the advent of Vista? I'm planning on a new PC soon, a basic media pc, and was wondering if the ol' XP dog was a cheaper option
  7. badders
    4 Dec 2007
    I know, that's what I paid for it - to me, that's a fortune, no matter what you spend it on.
  8. Glider
    Glider /dev/null
    2 Aug 2005
    Yeah, with a quad core and a 8800GT it does seem you don't have a lot to spend on your PC, and certainly not on key components like for instance an OS :sigh:
  9. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    I paid £96 for my copy of Ultimate, OEM, and while it's well over what I want to pay for it, it's not a fat lot more expensive than XP was/is (£73 (OOS) on Ingram Micro), or even Leopard (£85).
    I don't ever recall them being 'cheap', and when people are spending hundreds on a homebuild (I've yet to see a prebuild come without a license), it's hardly unfair to ask them to pay for the software that they're going to use day in, day out for the next few years.
    Complaining about the cost, even though it seems pretty damn extortionate, isn't going to change anything. If it's that much of a bind, get a copy of Linux, they're nearly all free.
    Admittedly, Windows does a very bad job of being 'nice' to users, but hey, that software is pretty much the base of everything we do. Not like we can change that too easily.
  10. badders
    4 Dec 2007
    No Not really.
    My PC was for christmas.
    Ninja Edit:
    This is more like what the point of my first post was - all stick, no carrot.
    There's no "Advantage" to having a genuine copy of windows, we just don't get crippled like the detected pirated versions.
    They should probaby have called it "WCD" - Windows Counterfeit Disadvantage
  11. Glider
    Glider /dev/null
    2 Aug 2005
    Well, if you don't get an OS you end up with a pretty expensive door stopper... Maybe you should have asked Santa for a bit less excessive CPU, and an OS to actually use your system.
    I just love it how people prioritise hardware over software, while software is actually more important than hardware... Bleeding edge hardware without software is useless, software without bleeding edge hardware still works, just a bit slower...
  12. azrael-
    azrael- I'm special...
    18 May 2008
    So, what flavour of Linux are you using? ;)
  13. badders
    4 Dec 2007
    I did buy my OS, but it doesn't mean I have to be happy about it.
    It's exactly the same as buying petrol at the price it is, I have to pay it, but I don't have to be happy about it.
  14. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    I have 4 comps, 3 with XP and one with Vista and ive never seen this WGA o_O ?
  15. liratheal
    20 Nov 2005
    I've never seen it getting in my face, I assume it has itself a mug or two of 'sit the **** down and shut the **** up' within legal copies.
  16. Glider
    Glider /dev/null
    2 Aug 2005
    Gentoo ;)
    That's exactly my point... You are perfectly happy to dish out for a quad core and gaming GPU, yet you complain when you have to pay for an other core component, the OS (which probably costs even less...)? To me that's flawed reasoning... That makes about everything too expensive...
    And in case you didn't know, if you hate MS so much, or dislike their practices, vote with your wallet... There are (free) alternative OSs... But live with the consequences of your choices. IMHO you should either STFU and pay the price, or do something about it and deal with the consequences. But that is most peoples problem, they whine and whine, yet they take the easy way out... But that's an other discussion I guess...
  17. scarrmrcc
    scarrmrcc What's a Dremel?
    12 Nov 2007
    look at it this way, apple OS's are cheaper, but you get a new every year.
    Windows costs more, but they update it all the time for free.
    essentially you are getting a deal with windows.
  18. wyx087
    15 Aug 2007
    am i the only one getting Vista (bith 32bit and 64bit) for free?
  19. liratheal
    20 Nov 2005
    I bet you're getting it through Uni, yes?
    Apple OS's are barely cheaper, though, there aren't any annoying license codes to put in, which is nice.
  20. OleJ
    OleJ Me!
    1 Jul 2007
    lol so in essence pirates get the better looking and performing Vista experience. Hahahaha!
Tags: Add Tags
