Watercooling how much?
Discussion in 'Hardware' started by TobletDanillio, 31 Mar 2012.
  1. TobletDanillio
    TobletDanillio Minimodder
    7 Jan 2012
    I'm would like to know how much it would cost me to make my pc water cooled.
    I would do the CPU and GPU.
    I have a 2600K and MSI 560-Ti.
    I have had a look on the market but I'm not sure what I really need.
    I know I need
    rad
    pump
    tubing
    tank (reservoir?)
    waterblocks
    Coolant
    I have been told that a good pump is Laing DDC 18w
    but I don't know if this over kill or not :S also that the Laing DDC 10w can be modded easily but soldering a link? :S
  2. rollo
    rollo Modder
    16 May 2008
    Graphics card waterblocks range from£40 to £150 ( just the gpu to full cover blocks )
    You need ram coolers if not using full cover on graphics
    CPU waterblocks between £40-£90
    Call it £200 for the rest and your in the ballpark, not in the house at the min or I'd give you some links to what I have used. And unless your using tap water you need some kinda fluid
  3. crazyg1zm0
    crazyg1zm0 Minimodder
    20 Feb 2007
    Im looking to water cool the same set-up pretty much just a diff GPU. for a full cover and some decent parts your looking about the £300 mark
  4. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    I don't think you can get a full cover block for that graphics card. You'd have to get a GPU block plus some VRM sinks etc. So that'd make it slightly cheaper. (Like rollo indicated)
  5. crazyg1zm0
    20 Feb 2007
    You can get full cover 560 blocks.
    But if he were to go for gpu and heatsinks it would be closer to £250
  6. noizdaemon666
    15 Jun 2010
    I know you can get full cover 560 blocks, but that specific card isn't a reference PCB design :p
  7. crazyg1zm0
    20 Feb 2007
    I bow to your knowledge :p and..... *run away*
  8. feathers
    feathers Minimodder
    11 Apr 2009
    Ok, you are in luck for the 560Ti... This GPU has heatsink cooling of the VGA core only thus all you need is an EK VGA Supreme block and 460 adaptor plate also from EK. Will cost about £48 total.
    The 560Ti doesn't have any heatsink cooling of the ram or PWM and thus is perfect for inexpensive VGA only block. The EK VGA supreme is a very nice jet impingement design that's taken the temps from 83c on air down to 37c on my liquid system at full load.
    Also note that the new 680 GPU also doesn't have heatsink cooling of the PWM so you could cool that with VGA only block.
    What I did was add some low profile ramsinks to the GDDR on my 2 liquid cooled 560ti... It's not strictly necessary. What u will need to do is have side fan on case or have a fan hang off the side of the GPU or blowing up from the bottom towards the component area.
    You don't need GDDR ram sinks also since the original 560Ti cooler doesn't use heatsinks on it. Just the small movement of air from the twin fans. Thus when u fit the VGA block u simply need to ensure there is some airflow going towards the GDDR and PWM. I have 2 x 560Ti with the EK VGA blocks... I have a 120mm fan sitting on the side (hanging off the top edge of top graphics card) and blowing air over both of my 560Ti.
    It's very simple and no problems.
    The 560Ti uses the GTX 460 PCB hence why u need the EK 460 adaptor plate with their EK VGA supreme. It's not worth buying a full cover block for the 560Ti.
    As for liquid cooling, I find air cooling boring and would never return to it.
    I love having 2 x 560Ti at 37c full load on a warm day.
    I use 12mm ID XSPC UV glow tubing.
    Swiftech Apogee V2 waterblock.
    EK DCP 4.0 pump because it's inexpensive (has RPM signal for motherboard), good head pressure.
    2 x EK VGA Supreme Acetal with the 460 adaptor plate for my MSI 560Ti.
    Thermochill PA 120.3 radiator.
    Giant XSPC 500mm heatsink reservoir tube.
  9. TobletDanillio
    7 Jan 2012
    something like this?
    link
  10. feathers
    feathers Minimodder
    11 Apr 2009
    "Not Found
    The requested URL /2https://www.aquatuning.co.uk/shopping_cart.php/bkey/de5724b034093c35a6fe0f744fbde0c8 was not found on this server.
    Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request."
  11. feathers
    feathers Minimodder
    11 Apr 2009
  12. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    What case are you using? Have a look at my thread (link in sig) :)
  13. noizdaemon666
    15 Jun 2010
    FTFY :thumb:
  14. feathers
    feathers Minimodder
    11 Apr 2009
  15. TobletDanillio
    7 Jan 2012
  16. rollo
    rollo Modder
    16 May 2008
    its not overkill but its not in stock either
  17. TobletDanillio
    7 Jan 2012
    Seeing how cheap it would be to WC my pc I think it would be stupid not to do it but my case (Sharkoon T9) isn't really the best case for WC plus I don't like it now so what would be a cheap but good case for WC?
  18. feathers
    feathers Minimodder
    11 Apr 2009
    When I built a PC for my GF last year, I chose an inexpensive case from ebuyer. I researched first and liked what I saw. The features it had you would normally find on expensive cases - 2 x side fan ports, front fan, top fan port, cpu cutout, bottom PSU mount, quick release side mount hard disk bays and most shocking - 2 x rubber grommited water tube holes at rear. The case cost £29 from ebuyer.
    http://www.ebuyer.com/172779-casecom-6788-all-black-case-km-6788-black
  19. dead beat
    dead beat Rippin six 4 life
    15 Feb 2009
    If your case has space limitations, then the Koolance RP401x2 is a great single bay reservoir. It will house two DDC pumps and has dual chambers which can be run serial or parallel, aswell as featuring front fill ports. I use one in my test bench.
  20. TobletDanillio
    7 Jan 2012
    my case has the two holes too so I could.
    what the koolance RP401x2? i can't see it on google
