Watercooling WC plan.
Discussion in 'Hardware' started by TobletDanillio, 6 Apr 2012.
  1. TobletDanillio
    TobletDanillio Minimodder
    7 Jan 2012
    I have been asking you guys for some help with WC over the last couple of days and now I'm putting all this information together.
    I want to make a parallel WC PC case the only thing is I don't know what tubing and fittings to get so please tell me whats better. pc spec in sig.
    What do you guys think of these items below?
    Case: Xigmatek Elysium spec link
    radiator: Phobya G-Changer 420 V1.2 (will fit on top of case right?) spec link
    pump + reservoir: Laing DDC+1 Ultra 18W with XSPC 200ml Reservoir Top spec link will is how the power need to do parallel?
    waterblocks CPU: EK Supreme LTX EN Nickel Acetal Spec link
    waterblocks GPU: EK HF Supreme VGA 460 getting from Parge so no link.
    tubing: no idea
    Fittings: no idea
    Coolant: Don't want UV as case has no window.
    thanks for you help guys
    Edit:
    If anyone is selling items please tell.
    also wheres good places to buy WC stuff?
