Case Mod - In Progress Thermaltake Casemod 2016 : Wine Cooling Completed !!!
Discussion in 'Project Logs' started by cucmag, 29 Nov 2016.
  1. cucmag
    cucmag What's a Dremel?
    31 May 2014
    Hello :)
    Then for my new project, I've the pleasure to participate at the Thermaltake Casemod Contest
    I'll work on a Core X71
    big case! though.... :hehe:
    we begin to remove some parts.....
    other....
    taking some measure...
    remove feets too....
    replace them by another but we'll see that later :D
    and we begin to play with the drill :dremel:
    the bottom part was rectified to be totally flat
    some holes on the rear part....
    ok! big holes
  2. cucmag
    31 May 2014
    Hello :)
    Then we continue with this alu profiles
    making a frame....
    for the new motherboard tray
    the acrylic plate is temporary, waiting for the aluminium plate
    but it helps to correct small errors :grr:
    the idea is to enlarge the rear space of the case
  3. cucmag
    31 May 2014
    hello :)
    we keep the rear panel with the I/O Shield
    the back part of the case being totally cut, we have put in place this new plate by reducing the number of opening to the minimum :dremel:
    the advantage of taking an accessory plate while waiting for the aluminum plate
    So we can adjust the position of the holes ... :duh::duh:
    strengthen the framework
    placing of the motherboard
    in order to identify the passage of cables
    ATX one
    CPU one
    some cutting...
    and we realize some little plate with wire to wire concept
    without forgetting the graphic card cable :)
    we finish this update with the opening for the power supply
  4. Cown
    Cown Minimodder
    25 Feb 2012
    Looks interesting, can you elaborate more on the plan for the build? Is it going to be a wine cooler or are you gonna use wine as coolant lol :D
  5. cucmag
    31 May 2014
    hello cown
    mainly is a mod dedicated on wine world
    but perhaps wine would be use on it....
  6. cucmag
    31 May 2014
    hello
    by speaking about wine :D
    cut in two .....
    another new alu plate !!! :duh:
    positionning at the bottom of the case
    two parts, same size :)
    fixing on the plate
    simulation on the case
    we'll adjust the cutting on the door
    thanks a lot reading me :)
  7. cucmag
    31 May 2014
    hello
    next update with ..... another alu plate :D
    we need this grid
    but not all...
    we keep the magnetic tape
    this plate is for the bottom of the case
    the opening coincide with the power supply
    better with this new grid
    we don't use the original feet....
    but these which are on cardboard box
    these one precisely :)
    some extra holes for fixation
    nice :)
    we take again the plate positionning on the front of the X71
    some cutting inside
    some sanding later
    we can now install the slim radiator
    see you :)
  8. cucmag
    31 May 2014
    hello :)
    then we an acrylic plate for the motherboard tray to facilitate the placement of the various holes
    we receive the aluminium plate, then we report the differents openings on it
    the concept of this tray is to have a space for the differents cables
    then we us some aluminium profile
    we makes some holes at different locations depending on the type of cable
    big hole on the second plate :D
    In situ with the main compartment
    and the low compartment
    front side
    completing with some cable channel on the front panel
    and some wood on its inner face
    visible through the big hole of the second plate
    acrylic plate to have a large window :hip:
    I hope we have enough holes for the cables :worried:
    [​IMG].
    placing in situ with motherboard and graphic cards
    back side
    front side with radiator
    and the "new" reservoir.... :D:D:D
    see you :)
  9. Cheapskate
    13 May 2007
    I see a custom wine label in your future.
  10. cucmag
    31 May 2014
    I have to choose what grape variety first :hehe:
  11. cucmag
    31 May 2014
    hello :)
    last day, we see our new reservoir
    but we keep the Thermaltake reservoir too
    the goal of the game is to get inside one another
    no 36 solutions....
    we need to cut the bottle
    we took rope and a bottle of alcohol to burn
    - "we wrap the rope around the bottle
    and remove the rope
    to put it on alcohol
    during this time we fill a larger container of cold water
    we put the rope back on the bottle
    we ignite the rope
    and we turn the bottle on itself so that the heat is distributed on all the turn
    when the flame goes out....
    we must quickly plunge the bottle into cold water
    "bling" yes! successful operation
    well .... the cut is not always as clear as we hope....
    we needed to repeat the operation on other bottles ...
    in order to achieve the expected result
    now we can dissimulate the Pacific reservoir on the bootle :)
    to the next time!​
  12. cucmag
    31 May 2014
    hello :)
    today we take care of graphics cards
    we receive the new Thermaltake waterblock for this Strix
    we have to remove the original heatsink
    and also the backplate"
    we take the instructions for use :search:
    Pad in place
    two grapic cards
    two waterblocks
    and two Thermaltake backplate :)
    but these backplate no fit with our theme based on wine cooling.... :eyebrow:
    new plate aluminium.... no actually we take a wooden board :D
    we cut it to the dimensions of the backplate
    we will bring him the little touch that sticks to the theme
    transfering it on the wooden board
    some black paint later....
    we begin removing the outer side of the stencil
    we continue on one side....
    - "and voilà !!!
    other wooden board
    new stencil but same player... picture
    always pay attention during the transfer so that all the details remain in place
    camouflage session for the rest of the wooden board before painting
    we have added a signature in relation to the previous model :)
    and we add some details on the edges
    two new backplate Wine Cooling
    see you soon​
  13. cucmag
    31 May 2014
    hello :)
    after the graphic cards, we have the motherboard also...
    the maximus formula VIII is already well prepared especially with its fairing
    more we can see a backlight placed in two locations
    but the ROG theme not fit with our theme.... and we want to have a more neutral color on this fairing
    more black....
    ... all black
    the name of this mod is Wine Cooling....
    so we take a little piece of aluminium with a wood veneer and we begin cutting the first letters
    a bit later....
    ...we tweak the cutting lines
    and.... voilà :)
    we make two little holes....
    and fix spacers
    bye bye Maximus VIII....
    welcome Wine Cooling!
    the cover of the chipset heatsink come with the ROG logo...
    so we take a llittle plate aluminium
    as the "Wine Cooling", we fix a wood veneer on it
    and we choose a new logo!
    we'll take advantage of the backlight coming from the heat sink
    that's all
    see you​
  14. cucmag
    31 May 2014
    hello
    aluminium plate !
    no! wooden board
    I'll play to the bricklayer....
    one piece by one piece
    all right! finish the second part too
    we tweak the details
    the small touch with some shiny mosaics
    why make a walll...
    to dress the location of the barrels :)
    I show you this in the case
    better with the barrels
    nothing better than to mount a wall to dress our cellar :D:D
    see you soon​
  15. Sharangir
    Sharangir What's a Dremel?
    18 Oct 2016
    love the idea!
  16. cucmag
    31 May 2014
    I'm glad you like it sharangir :)
  17. cucmag
    31 May 2014
    hello :)
    the last time, we can see the barrels in place on the X71"
    but we can see another updapte on this X71"
    we had finished the new structure of the case with our new aluminum plates
    but we were not going to leave the case as well ;)
    so.... all in black !!!!
    main compartment as lower compartement....
    black :cooldude:
    on the back
    black :p
    underneath
    black too...
    well not all :rolleyes: we keep the feet unchanged
    backstage side, we had protected the inner face which contains the wood veener
    we can notice two small details at this level
    this cutting ....
    the second detail take place upper
    two long screw ....
    but at this moment, I can not say more about them :duh:
    thanks reading me :thumb:
  18. cucmag
    31 May 2014
    hello :)
    now we have completed the structure of our X71
    so we can beginning to customize inside the case
    we take a wooden board on which we made a hole
    we cut it to the right size
    new stencil!
    we transfer it on the wooden board
    counter to the backplates, we took a brown paint
    we remove the stencil
    starting with the letters
    then we take care of the castle
    et voilà !!! :)
    like a board of wine bottle boxes
    here is how the board in the case
    see you soon​
  19. cucmag
    31 May 2014
    hello :)
    today we care of the front radiator
    we take an aluminium plate....
    we stay on the red wine theme
    some vine leaves and a bunch of grapes
    we would cut this with our scroll saw
    before we have drill some holes
    and we start quietly with the first vine leaf
    then, we continue on the others vine leaf
    few minutes later.....
    ok....few hours later :hehe:
    we finish all the cutting
    we begin sanding the plate
    As you can see, we added a few cuts on some vine leaves
    and we folded one of the edges of the plate to cover a little more the radiator
    the idea is to put a backliight to bring out the cut
    yes! because we paint the fairing in black ;)
    before leaving for an upcoming update
    here is a small video of my use of the scroll saw
    Merry Christmas :)
  20. HandMadeAndroid
    HandMadeAndroid That's handy.
    18 Feb 2005
    I was just thinking: it's about time a mod was done with a wine cellar :D
