News Leaked slides point to Skylake GPU performance boost
Discussion in 'Article Discussion' started by Gareth Halfacree, 24 Jul 2015.
  1. Gareth Halfacree
    4 Dec 2007
  2. Hustler
    Hustler Minimodder
    8 Aug 2005
    10-20% CPU boost?
    ...that's quite a bit higher than the 3-5% everyone has been estimating so far.
  3. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Is that because there's no Broadwell S series?
  4. dylAndroid
    dylAndroid is human?
    31 Mar 2008
    On some level, I find integrated graphics gains disappointing. I'll be using a desktop with discrete graphics, but some of the price and design I see will reflect a feature that doesn't have value to me.
    Though, of course, a better minimum graphics baseline helps software developers, which in turn, does benefit me, so I can't really complain.
  5. theshadow2001
    3 May 2012
    Funny how leaked slides look like media releases and usually appear around release time for products.
  6. Corky42
    30 Oct 2012
    I thought they carried the C suffix, basically a desktop part but with high performance graphics.
  7. rollo
    rollo Modder
    16 May 2008
    It depends how much Intel cares for AMD. If they do not care at all a I3 with this GPU on it would be pretty much the end of the road, more so if they decided to just undercut them drastically. Sell a I3 with this gpu for under £100 job done end of market for APUs.
    Intergrated graphics are about on par with a 560ti in terms of performance so they have come a long way. Intel are basically been forced to cater to a few peoples needs with there IGPU.
    Maybe they fear ZEN might be good and are aiming for a 20% boost in there performance metric. Its not within reason that Intel could drop a 20% faster cpu and a 50% gpu boost if needs be.
  8. Mr_Mistoffelees
    26 Aug 2014
    Nothing like letting a few snippets of information "leak," to get the free publicity mill working.
