I'm trying to squeeze as much performance out of this as I can for the next few months until I can get some money flow and upgrade. I had the CPU at 3.0GHZ but it was awfully unstable, I know this cpu you can handle 3.8GHZ under optimal settings. I'm only looking to get around 3.1Ghz-3.5Ghz out of it, Also with optimal ram speeds as well. I've never got in to overclocking so I'm pretty much looking for a dummy guide. I've check around the internet and haven't found to much, maybe I'm not looking in the right places. Any help would be much appreciated. The sad part is I can run Skyrim, more or less maxed out, but I can barely run All Points Bulletin on the lowest settings.
Any ideas on keeping a stable overclock? I've been messing around with settings and can't seem to get any where with it.
