This is my first strach build that i made for HW gurus case modding competition 2013. Components that i used are: Gigabyte 970a-ud3 Phenom II X4 955BE Thermaltake ISGC-300 with coolermaster fan XFX Radeon HD 6790 Corsair 4GB 1333MHz LC Power 550W WD Caviar Black 500GB sata II Aerocool modern v Scythe sllip stream slim 120mm And here are photos: back panel Top panel Front panel Side panels HDD case motherboard offset Button everything painted everything compledet In the next post i will upload final pictures and movie.
I like the overall design! Very straight forward and without too many frills. Just basic clean and functional! But I must say I am not a big fan of how the panels connect to each other...there seems to be some gaps in the corners? Maybe you could use some pieces of angled Alu in the corners, connected to the top and bottom frame to hide the gaps and increase stability? Anyway, what Vetalar might be referring to is your picture size. The forum resizes em for you, but they still take quite long to load. Maybe use picture resizing tool to have them load a tad bit quicker.
Yeah you might want to resize those pictures both in dimension and filesize. After that, add some pics of the internals please
If I had the patience to wait an hour for the pictures to load my comment would probably be more meaningful. Alas, it is not and I will result to 1/2 trolling and 1/2 constructive critisism. I would encourage you to use either thumbnails or smaller pictures in worklogs
