So I bought the Phobya DDC pump top link (actually the combo) and I'm trying to use the side 2 ports for my in and out, but the fittings I bought do not fit. I was then going to order 90 fittings for the top, but I want to make sure they'll fit. Does anyone know what 90 fittings will fit this pump top using both the side ports? Here are the fittings I bought: Fittings Seperately, does anyone know of a plug that I can use for the other 2 ports? I have the ones included with the top, but they stick out enough to get in the way of the rest of the build. I would like to use 2 plugs that are flush with the top. I know that to seal the threads, I need the o-ring, but I was going to use some locktite to seal them in place. I've used it for compressed air for a sealant at 100+psi so I would assume that it would hold the pressure.
Any 90 degree fitting with a small outer diameter would fit. (Bitspower, acool) . The bulky stuff like primochill or monsoon will not fit. I don't think there are flush stopping plugs, Bitspower has low profile stop fittings, but they're still 3mm high; http://www.bitspower.com.tw/index.php?main_page=product_info&cPath=6_27_28&products_id=502
