Case Mod - In Progress Purpura (XPS 720) Completed !!!
Discussion in 'Project Logs' started by alain-s, 5 Jan 2014.
  1. alain-s
    alain-s Minimodder
    12 Jan 2011
    This will be the start of a new project. Purpura
    For this build I am going to use for an old acquaintance. In the summer of 2013 I had the change to get my hand on 2 XPS 720 cases. I will use these 2 beauty's to create 1 complete case.
    The hardware and water cooling parts will be reused from my previous build Bel Air. Because I never got to finished the mod I will be using most of the parts that where sponsored then.
    Sponsored by
    The black Case came complete with hardware when I bought it. The only thing that was missing was the foot of the case. That is why I got the other one I also will use they silver case for donor parts.
    Dell created a really good system to open 1 side panel in seconds with these series. But the other panel was a nightmare. U had to remove all the hardware before U could reach to the screws of the other panel. This system would not be handy at all of u wanted to do some tight cable management.
    This is where the donor case will come in handy. I removed the mechanism from the case and install this in the case that i will use my self.
    Removed the profiles from the top and bottom plate and removed all the double-sided adhesive tape.
    Making sure that the profiles stay on the same place before I can fasten it.
    To Fasten the profiles I will use 2 methods. First I use 2 compound metal glue the other type will be rivets this way they will never come loose again.
    Where the rivets where placed I had fill up the hole and sand them even with the panel.
    Coming up next will be the side panels and the slot mechanism.
    Till next update!
    Pranja likes this.
  2. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    Finally the build log! Very cool to see another 720 being modded :)
    Based on the sneak previews I had all I can say is: it's going to be awesome! Keeping a close eye on this ;)
  3. alain-s
    alain-s Minimodder
    12 Jan 2011
    Thank U Martijn,
    This will be fun ^^ 2 modders with different styles looking forward to see what U will make out of it. :)
  4. Pranja
    Pranja Blackwolf
    18 Dec 2011
    I can't wait to see what will you do with those cases.
  5. ali_robb2000
    ali_robb2000 What's a Dremel?
    17 Feb 2003
    Looking forward to another of your builds, will be good to see how this turns out!
  6. alain-s
    alain-s Minimodder
    12 Jan 2011
    Thank u guys :)
    Update!
    Time to work on the side panels and the slot mechanism.
    This is how the original mechanism looks like.
    Made a small adjustment with the dremmel. Removed all the material that is not needed anymore.
    Repeated it 2 times for every panel of the case.
    Did the same on the bottom of the panels.
    The only rested to do was to remove the double-sided adhesive tape from the panels.
    Now when there ready it is time to test it. And see if the systems works ok.
    Thank u for reading till next update!
  7. Meelobee
    5 Nov 2003
    It looks so familiar! oh wait! ;)
    Looks good Alain :)
  8. alain-s
    alain-s Minimodder
    12 Jan 2011
    Idd Martijn good thing we talked about it on FB ^^
  9. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Awesome! Can't wait for more.
  10. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    You have my attention sir, I always likes those cases. Looking forward to this.
    J.
  11. Idioteque
    Idioteque Telephasic Mongoose
    21 Aug 2004
    I do like these cases. Shall keep a close eye on this.
  12. TekLord
    TekLord Tek by Design
    7 Jan 2012
    You have my attention.
  13. alain-s
    alain-s Minimodder
    12 Jan 2011
    Thank U guys, here is a small preview for the next update.
  14. Nexxo
    23 Oct 2001
    Oooooh! Tasty! :eeek:
  15. alain-s
    alain-s Minimodder
    12 Jan 2011
    Thank U Nexxo,
    Update!
    A few weeks ago I went to visit Pascal to pick up some parts for the build. For the build I choose to go with a new front,back plate + a new motherboard tray. This way I have more option for the case.
    This was the first idea/theme that I wanted to use for this project.
    After a while I dissected to create something that really would fit with the elegance from the case.
    These where the parts that I picked up at Pascal.
    The only things that needed to be done where bending and drilling holes for the mounting.
    After a few hour Pascal and me where done with all the work and the case could be assembled for test.
    Thanks again Pascal to help me with this project. :D
    Frontplate
    Rad mount
    Backplate
    Motherboard Tray
    There where only a few thing that still needed to be done like drilling the holes for the stand offs and pci brackets
    Assembling of the case.
    [​IMG][​IMG]
    [​IMG][​IMG]
    [​IMG][​IMG]
    This was it cya till next update. ^^
  16. Meelobee
    5 Nov 2003
    That's so awesome, glad you took the second design as it suits the case alot better :)
  17. Nexxo
    23 Oct 2001
    ...And the tasty just keeps on coming! :eeek:
  18. alain-s
    alain-s Minimodder
    12 Jan 2011
    Thanks Martijn ^^
    Thank U Nexxo ^^
  19. alain-s
    alain-s Minimodder
    12 Jan 2011
    Update
    Last weekend I had some time to continue my work on the case. I started to make a support for the DVD and bottom plate. Used 2 alu profiles for this. To attache them I used 2k glue and rivets to secure to the bottom plate.
    Still need to make a cover for the DVD I will do that when the new materials arrive.
    Few weeks back I visited Sander from MWM to help him a bit with building some mining pc's. In return he made a few parts that I needed for my cable management.
    The pieces have bin polished and sanded to get the frost look.
    Mounted it at the back of the motherboard tray.
    This way the power cables will run nicely next to each other.
    Next step was the front/back of the case.
    Before
    After
    Same for the back panel.
    Installed the polished pieces in to the front.
    In every open space will come a piece of aluminum. This will give a nice retro look for the front.
    This was it again cya at the next update.
  20. Waynio
    Waynio Relaxing
    20 Aug 2009
    Looking super nice. :D
