Graphics Radeon 9700 Pro Probs
Discussion in 'Hardware' started by (Ck)Vegeta, 20 Nov 2003.
  1. (Ck)Vegeta
    (Ck)Vegeta What's a Dremel?
    23 Jan 2003
    Im getting this Error when i try and install my Radeon 9700 Pro onboard is disabled.
    This device cannot find enough free resources that it can use. (Code 12)
    If you want to use this device, you will need to disable one of the other devices on this system.
  2. Krikkit
    21 Jan 2003
    Doesn't sound like your onboard is disabled to me, that's the only reason i can think of. Try removing some PCI cards if you have any, that might help. Otherwise, just double check it's really disabled...
  3. Froggy
    Froggy What's a Dremel?
    10 Jun 2003
    this might sound a little extreme but try unplugging any unnessicary drive, remove unnessacary pci cards and anything else that can be unpluged. if that dosent do it go in to BIOS and do something like "load fail safe defaults". make sure the onboard stuff is all disabled to.
  4. (Ck)Vegeta
    23 Jan 2003
    I baught a New Mother Board got it all up and running now. I guess my Current mobo wouldnt take ATI cards. but it took any Geforce perfectly fine. Thanks for the Info tho
  5. Froggy
    10 Jun 2003
    sounds like you have a nforce board. what a waste of money.
  6. (Ck)Vegeta
    23 Jan 2003
    No actually my NEW Mobo is an NForce 2 Board Specs Below:
    Specifications:
    Supported CPU:AMD® Athlon™XP/ Athlon™/ Duron™ 600MHz ~ 3000+
    Chipset:Nvidia nForce2 400 + nForce2 MCP
    FSB:400 / 333 / 266 / 200 MHz
    RAM:3 x 184-pin DDR 400 PC3200,2700,2100,1600 up to 3GB
    IDE:2 x UltraDMA 133/100/66/33 Up to 4 Devices
    Slots:1 x AGP 8X (1.5V only) 5 x PCI
    Ports:2xPS2,1xLPT,1xCOM,4xUSB,1xLAN, and Audio Ports
    Onboard LAN:Realtek® 8201BL PHY 10/100
    Onboard Audio:ALC650 6CH w/built in HP amplifier More... Model#: A7N8X-X
    Runs Awesome only paid 75 bux
