Windows How many times can you use a windows 7 key?
Discussion in 'Software' started by carebear, 14 Jan 2011.
  1. carebear
    carebear What's a Dremel?
    12 Jan 2011
    I've just been reading through the forums a bit and it came to me to ask how many times can you use an actual key?
    I got a free copy of Windows 7 Professional 64bit from University and I got a number of different keys for it.
    English 32+64bit
    Chinese 32+64bit
    Total of 4 keys. I've personally reinstalled my windows 64bit a number of times and used the english 64bit key every time. There must be at least 5 occasions in me doing this.
    Is that key mine for as long as I like or it their an actual limit and it may not work in the future? Then would the chinese or 32bit keys work in replacement?
  2. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    You can use one key once concurrently, unless you have a corporate/volume key which will allow n depending how many you bought.
    You can reinstall your operating system as many times as you freakin' well want :thumb:
  3. carebear
    12 Jan 2011
    Awesome thanks. I just wanted to make sure incase I hit any limit because I'm going to be building a new build this month and I didn't want to have to go and buy a new copy.
  4. jrs77
    jrs77 Modder
    17 Feb 2006
    If you're going to change hardware (motherboard) you might have to call M$ to explain and get the activation.
    So long as you don't change hardware, you can reinstall W7 as often as you want with the same key.
  5. Everydayoddity
    Everydayoddity What's a Dremel?
    13 Jan 2011
    Is that the same with OEM and retail? I've never really understood how this works with new mobos etc.
  6. jrs77
    jrs77 Modder
    17 Feb 2006
    OEM is completely tied to the motherboard basically, e.g. it's tied to the system it's sold with, like Dell-PCs or notebooks etc...
    The retail-version can be activated, even if you switch out the motherboard or swithc to a completely new system, but you might be requested to give M$ a call to receive a new key by phone, explaining yourself.
  7. Showerhead
    Showerhead What's a Dremel?
    11 Jan 2010
    Way I understand it Retail you can install as many times as you want as long as it's only on one machine at a time.
    OEM if you make a major hardware change, which i assume means CPU or mobo as I changed every other component on my OEM vista license, you'll have to phone up to get the key reactivated.
  8. jrs77
    jrs77 Modder
    17 Feb 2006
    It's allways limited to a single PC, and you can aswell reinstall it as many times as you wish.
    However, even the retail-versions can't be activated online automatically, once you change your motherboard, but require a phone-call.
    And OEM... these are tied to the bought system and originally don't qualify for changing hardware yourself. In most cases you don't even get a DVD, when you buy a system including an OEM-version of Windows.
  9. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    I changed my entire PC apart from HDD a few months back and used my Vista OEM disc I got with my previous computer. Activated no problem over internet lol
  10. jrs77
    jrs77 Modder
    17 Feb 2006
    Good we're talking about Windows 7, isn't it?
  11. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    OEM XP re-activates very easily, just call the automated phone line, type in a number, write down a number & type that into the PC = windows is now reactivated. I imagine its the same for shista & 7 too. At worst, you'd have to make up a story about the mobo dying and buying a new one, then they'll give you a new key to re-activate windows with- this is a very common issue/question indeed...
  12. st1x
    st1x Surviving on low specs since '86
    24 Apr 2010
    If you were to install win7 32 bit on say an old socky 754 setup, would it recognise the 64 bit on another more powerfull, yet to be built system?
    Totally hypothetically speaking of course ;)
    Nic
  13. jrs77
    jrs77 Modder
    17 Feb 2006
    Your serial number and a checksum/hash based on your hardware is sent to the M$-server and an activation-key is generated out of it.
    So installing a 32-bit and 64-bit version simultanously with the same serial number isn't possible.
    Aslong as the checksum/hash doesn't change (usually based on the motherboard-ID) you can reinstall and automatically activate your system as often as you want. Once the checksum/hash changes, you're required to get a new activation key.
  14. faugusztin
    11 Aug 2008
    There is a subtle difference between possibility and legality of such move. Legally, you are not allowed to transfer a OEM licence from one motherboard to another, except rare cases where MS allows you to do that (motherboard RMA). The fact that activation process didn't stop you doesn't change the fact that if anyone would check your licences, by the law your licence would be invalid.
  15. BennieboyUK
    BennieboyUK CPC Folder of the Month Sep 2011
    24 Nov 2010
    This is very true however user replaceable parts, such as gfx, ram and HD can be changed on oem without invalidating the lic.
  16. faugusztin
    11 Aug 2008
    Thats why i said motherboard :). And noizdaemon666 changed everything except the hard drive ;).
