PSU GTX 480 SLI Power Draw - Figures Revealed
Discussion in 'Hardware' started by LennyRhys, 31 Jan 2013.
  1. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    Well you got there in the end :D Here are the figures from my "rigorous" testing:
    (Power draw was measured at the wall for the entire system, not just the GPUs)
    1) Heaven Benchmark, both cards at stock: 585W (peak)
    2) Heaven Benchmark, both cards at SOC speed: 608W (peak)
    3) Furmark Burn Test, both cards at stock: 610W (peak)
    4) Furmark Burn Test, both cards at SOC speed: 661W (peak)
    I was amazed to see such low figures given how much "power hog" propaganda there is about the GTX 480. Well this should dispel any myths...even with both GPUs overclocked significantly (and overvolted), the power draw at 99% load stayed well below 700W.
    I'm currently installing the latest F@H client to see how it compares with Furmark. :thumb:
    TaRkA DaHl likes this.
  2. Parge
    16 Jul 2010
    778W
  3. fuus
    fuus Misses Rep Bombs
    4 Dec 2010
    900W
  4. Teelzebub
    27 Nov 2009
    823W
    What do we get if we win
    YEHBABY likes this.
  5. Parge
    16 Jul 2010
    Probably a burnt out Thermaltake Toughpower 775W
    YEHBABY likes this.
  6. The_Crapman
    5 Dec 2011
  7. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    999W
  8. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    LOLOL :D My Toughpower has survived much worse than this... it survived the short that killed my Bloodrage :waah:
    Keep the guesses coming folks. :rock:
  9. TaRkA DaHl
    TaRkA DaHl Modder
    15 Mar 2011
    947W.
    Has to be higher than the PSU 'maximum' rating otherwise you probably wouldn't create a thread about it :)
  10. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
  11. jizwizard
    jizwizard Modder
    24 Dec 2010
    Well for the cards on there own your looking at 660w ish so high 900 low 1000
  12. fuus
    4 Dec 2010
    1001W
  13. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    God, at a guess? You must've been pulling way over the PSU's rated max from the wall, accounting for PSU efficiency, and how damn hungry 480's are under load. I'm hedging my bet at 790W.
  14. Madness_3d
    Madness_3d Bit-Tech/Asus OC Winner
    26 Apr 2009
    775W? :p My system is 830W at the wall so given a 930 is a bit more efficient?
  15. jizwizard
    jizwizard Modder
    24 Dec 2010
    The 930 will sup more power than your phenom but only just
  16. Harlequin
    Harlequin Modder
    4 Jun 2004
  17. rollo
    rollo Modder
    16 May 2008
    860-900 watts
    you would break 1kw if you overclocked both cards.
    and maybe if you broke out furmark you would see it as well.
    Unique heaven does not stress the cards like furmark though
    Id say 700 watts would be my guess.
  18. Pookeyhead
    30 Jan 2004
    over 9000!!!
  19. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    LOL Pookey :D
    So far, rollo is far closer to the real figure than anybody else. He is also correct that Heaven doesn't stress the GPUs as much as Furmark might (but I ran Furmark too... all will be revealed shortly).
    I'll give you a clue and I still don't think anybody will get it right:
    Peak power draw for the entire system whilst running Heaven was below 700 watts.
    Keep the guesses coming. :D
  20. jinq-sea
    15 Oct 2012
    698W? ;)
